I'm wondering if a Rasberry Pi could replace a PLC (Programmable Logic Controller) for machine control. I need three inputs, each sensing 14v AC. If either of the inputs sees 14 v, I need an output of dry contact pulses (like you would get from a water meter). Further, I need to be able to vary the frequency of the dry contact pulses (number of pulses per minute) because the pulses are going to a chemical pump and I want to be able to vary the output of the pump. From what I have read, I may need a GERT board and maybe Arduino? The alternative is to get an inexpensive PLC and use ladder logic.
