Hello again,
Regarding the PiDrive I honestly don't need it since I have a bigger sized hard drive plugged in over USB
I've had the patched Pi2 with said PP5 and PP2 to USB VCC and ground running for 6 hours now and no problems whatsoever
overclocked @ 1GHz it's running at an average of 50ºC (can climb up to about 58ºC at peak when running media off the hard drive). I don't know that much about electronics but at least I can assure that it's running pretty fast and solid, no lag when playing back 720p and 1080p media @ 30 fps (just takes maybe a second or two to load the files probably due to the access time inherent of the hard drive).
Upon closer examination, the parts that are missing/not looking as good from the board are the following: Q4 (missing), and R48 (looks like slightly burned or something. hard to see without a microscope/magnifier for me). Everything else, besides a tiny bit of solder between R50 and R4's ground pins as rpdom told me to try is in perfectly fine condition.
If anyone else could give more feedback about any considerations I should take (besides replacing it, I know that maybe I should but it's kind of a waste considering that the system runs perfectly!) I would really appreciate it.
Thanks again for all your help!
