Fester Bestertester
Install woes: back to CLI ...
Thu Feb 09, 2017 3:06 am
Probably a newbie issue. Downloaded latest Raspbian (2017-01-11). Last Install README said "unzip to card". OK, 15GB card - check. Kubuntu's Partition Manger Formatted fat32 - check. Unzip with ark, no containing folder - check.
Fail to boot. Unzip to folder, copy (.img - ?) to card -no, that's not right. Startup Disk Creator writes .img files,so ...
No boot. Back to Command-line:
~...$ sudo dd bs=4M if=2017-01-11-raspbian-jessie.img of=/dev/sdb
1042+1 records in
1042+1 records out
4371513344 bytes (4.4 GB, 4.1 GiB) copied, 320.641 s, 13.6 MB/s
SUCCESS!
May need better README? YMMV
Re: Install woes: back to CLI ...
Thu Feb 09, 2017 3:19 am
Fester Bestertester wrote:Probably a newbie issue. Downloaded latest Raspbian (2017-01-11). Last Install README said "unzip to card". OK, 15GB card - check. Kubuntu's Partition Manger Formatted fat32 - check. Unzip with ark, no containing folder - check.
1042+1 records in
1042+1 records out
SUCCESS!
The latest Raspbian Jessie with Pixel is a .ZIP which when unpacked is an .IMG file:
https://www.raspberrypi.org/documentati ... /README.md
Writing an IMG to a SD Card removes all previous data / formatting so have no idea why you a messing around with formatting etc..
RPi 4B 4GB (SSD Boot)..
Fester Bestertester
Fri Mar 24, 2017 7:58 pm
Old post, resuming:
You: "Writing an IMG to a SD Card removes all previous data / formatting so have no idea why you a messing around with formatting etc.."
finding out that it was irrelevant because
Me: "Startup Disk Creator writes .img files,so ..."
Please READ MY POSTS before knee-jerk reacting. Startup Disk Creator is not a Raspbian app, and a Pi does not write cards, ipso facto it was run on another system that did - in my case my Kubuntu desktop 'workhorse'.
"... No boot. Back to Command-line:
1042+1 records in
1042+1 records out
SUCCESS!"
'nuff sed?
Fri Mar 24, 2017 8:16 pm
FYI Etcher can undertake the require steps of unpacking the Jessie .zip and write the .IMG file:
https://etcher.io
Return to “Raspberry Pi OS”
