when I try to change my keyboard layout
from menu>>preference>>mouse and keyboard setting
it is change, but after reboot or restart it is become default setting
my os
Raspbian 8 (jessie)
I suggest that you replace SD card, it is not unusual for SD cards to go into a read-only state when faulty. The symptoms are that the card accept writes but after power off this information has disappeared. What you could do is to create a file with some text in the home directory and see if this exists after reboot.
The road to insanity is paved with static ip addresses
When you change the keyboard you make a change in the configuration stored on the SD card. If this change disappears after a reboot then it may well be possible that the card is faulty and your configuration change was not written permanently to the card.
