solo2500
syntax error on except KeyboardInterrupt:
Sun Feb 05, 2017 8:41 pm
I'm getting a syntax error on the except KeyboardInterrupt: at the end of this program... Any ideas?
#!/usr/bin/python
# SoloJW
# This script controls a fan based on CPU temperature.
# It expects a fan that's externally powered, and uses GPIO(BCM) pin 26 for control.
import RPi.GPIO as GPIO
import time
import os
# Return CPU temperature as float
def getCPUtemp():
        cTemp = os.popen('vcgencmd measure_temp').readline()
        return float(cTemp.replace("temp=","").replace("'C\n",""))
GPIO.setmode(GPIO.BCM)
GPIO.setup(26,GPIO.OUT)
#GPIO.setwarnings(False)
GPIO.output(26, GPIO.LOW)
time.sleep(2)
while True:
        CPU_temp = getCPUtemp()
        print'CPU TEMP=' , CPU_temp
        if CPU_temp > 51.5:
                GPIO.output(26, GPIO.HIGH)
                print'FAN ON... CPU TEMP=' , CPU_temp
        elif CPU_temp < 50.0:
                print'FAN OFF... CPU TEMP=' , CPU_temp
        time.sleep(5)
GPIO.cleanup()
Thanks for any help!
I'm a total novice, non-programer (...basically a hack.)
pcmanbob
Re: syntax error on except KeyboardInterrupt:
Sun Feb 05, 2017 8:58 pm
Hi.
you need a try: statement.
like this
try:
	while True:
			if CPU_temp > 51.5:
			time.sleep(5)
	GPIO.cleanup()
then it works ok.
rpdom
Sun Feb 05, 2017 9:03 pm
An "except" needs a "try" at the start of the code block.
solo2500
Sun Feb 05, 2017 11:26 pm
THANKS SO MUCH!!!
Return to “Beginners”
