G'day, I have a question regarding the output of the gertbot motor controllers, there are 4 outputs @ 2.5 amp, I understand this rating can be canged by resoldering the board (i want to avoid this if possible) is there an amplifier circuit that I can use to boost the pwm signal? I want to use the bot to power my garden Railway, unfortunately it requires up to 10 amp.
Ideally I could connect the gertbot output to a seperately powered amplifier/booster so it can handle up to 10 amp is this possible, or am I better off resoldering the bot?
