EvanBot
Raspberry Pi Zero Wifi, etc...
Sat Feb 04, 2017 3:02 am
I'm a complete noob, I bought a kit from Adafruit to build a handheld console with retropie, the problem is the usb Hub that I bought doesn't seems to work...
I have a raspberry pi 3 is it possible to configure the sd card through the raspberry pi 3 and then switch it to the zero ??
peterlite
Re: Raspberry Pi Zero Wifi, etc...
Sat Feb 04, 2017 3:40 am
You can build most things on the Pi 3 then move the card to a Zero. I do it all the time. If you are plugging something into the Zero, the driver may be different to the drivers installed for the Pi 3. Plug the device into the Pi 3 to make sure you have a working driver.
Compiling applications is different because the processors are slightly different.
Sat Feb 04, 2017 8:04 am
EvanBot wrote: I have a raspberry pi 3 is it possible to configure the sd card through the raspberry pi 3 and then switch it to the zero ??
Yes. I do that all the time
If you start with 2017-01-11 Raspbian or NOOBS 2.1, configure it on a RPi3 it will work on a Zero.
