Shantanu24
Raspberry pi + TTL RFID Reader + USB to ttl converter
Fri Feb 03, 2017 12:15 pm
Hi.
I have a TTL RFID Reader with 3 wires (12V, GND and TXD)
I have one USB to ttl converter and one Raspberry pi 3
I have done connections as follow:
RFID USB-TO-TTL
GND-----GND
TXD------RXD
Given an external 12V power supply to the RFID reader.
When I do the above connections and plug in the usb end of the usb-to-ttl converter into the Raspberry pi, when i give the command
lsusb
it shows
Bus 001 Device 006: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Also with the command
ls -ltr /dev|grep -i ttyUSB
it shows
crw-rw---- 1 root dialout 188,   0 Feb  3 16:47 ttyUSB0
So I am guessing the device is connected at least.
Now I use the following python code to try and read a RFID card
from time import sleep
import serial
ser = serial.Serial('/dev/ttyUSB0', 115200)
while True:
    print ser.read(12)
But all i see as output are blocks.
No data
I also tried different baud rates. But in vain.
What could be the problem?
SSJ
Re: Raspberry pi + TTL RFID Reader + USB to ttl converter
Fri Apr 28, 2017 4:15 am
Using an EM18 reader and we're facing the same issues while using the USB to ttl.
Kindly post the solution, if you find any. Thank you.
Return to “Beginners”
