aBUGSworstnightmare
Re: How to let pi work with 240x400 LCD?
Fri Feb 03, 2017 11:11 am
the display of your choice has a MCU interface with read/write/enable signals. Don't know if there's a driver for these kinds of displays available.
There are a lot of cheap modules out there with an RGB interface (18- or 24bit parallel, means 6 or 8-bits per color) which can be connected to the RPi DPI interface directly, requiring some adapter (most of them have FPC connectors) only.
4.3in from Ortustech - 24-bit color, simple FFC/FPC adapter PCB from adafruit
