Hi, I wanted to make an IR LED motion trap, using IR LED and IR phototransistor, to know, if someone entered or exited a room. But the problem is, that the range is only about 10-15cm. Is there any way to make the range at least 1m?
Currently the LED is powered by 5v source with current limiting resistor of 150 ohm.
Thank you for any answers.
