Akira1912
Adafruit pn532 NFC breakout
Tue Jan 31, 2017 5:52 am
i used the adafruit pn532 breakout to read nfc but everytime i try to use it i get this error:
/home/pi/libnfc/libnfc-master/examples/.libs/lt-nfc-poll uses libnfc 1.7.1
error libnfc.driver.pn532_uart
pn53x_check_communication error
Unable to transmit data. (TX)
lt-nfc-poll: ERROR: Unable to open NFC device.
I used this guide to install everything and have tried with both libnfc 1.7.1 and 1.7.0:https://learn.adafruit.com/adafruit-nfc ... spberry-pi
topguy
Re: Adafruit pn532 NFC breakout
Tue Jan 31, 2017 1:28 pm
The guide is a little old, the method for freeing up the serialport and also the name of the serial-device has changed for RPi3 and newer versions of Raspbian Jessie.
That means that the name of the serialport that you set in "/etc/nfc/devices.d/pn532_uart_on_rpi.conf" has changed, most probably to "/dev/ttyS0".
Do a "ls -l /dev/ttyACM0" and "ls -l /dev/ttyS0" and check which one you have.
Akira1912
Thu Feb 02, 2017 2:07 am
thanks it worked
lordvos
Tue Jul 11, 2017 3:24 am
Thanks, mate - that was a quick fix (that I wish I had found an hour ago).
LV
SoftwareElec
Thu Aug 06, 2020 3:52 pm
I had a similar issue as to the one above:
pi@raspberrypi:~/libnfc/libnfc-1.7.0/examples $ sudo ./nfc-poll
/home/pi/libnfc/libnfc-1.7.0/examples/.libs/nfc-poll uses libnfc 1.7.0
I changed the port from ttyACM0 to ttyS0 in the /etc/nfc/devices.d/pn532_uart_on_rpi.conf and rebooted the PI but i still get the same error as above.
