i wanted to use the mcp2515 with spi2.
That´s why i changed the config entry into
dtoverlay=spi2-1cs,cs0_pin=43
dtoverlay=mcp2515-can0-spi2,oscillator=16000000,interrupt=25Code: Select all
* Device tree overlay for mcp251x/can0 on spi2.0
/dts-v1/;
/plugin/;
compatible = "brcm,bcm2835", "brcm,bcm2836", "brcm,bcm2708", "brcm,bcm2709";
/* disable spi-dev for spi2.0 */
fragment@0 {
target = <&spi2>;
__overlay__ {
status = "okay";
fragment@1 {
target = <&spidev0>;
__overlay__ {
status = "disabled";
/* the interrupt pin of the can-controller */
fragment@2 {
target = <&gpio>;
__overlay__ {
can0_pins: can0_pins {
brcm,pins = <25>;
brcm,function = <0>; /* input */
/* the clock/oscillator of the can-controller */
fragment@3 {
target-path = "/clocks";
__overlay__ {
/* external oscillator of mcp2515 on SPI2.0 */
can0_osc: can0_osc {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <16000000>;
/* the spi config of the can-controller itself binding everything together */
fragment@4 {
target = <&spi2>;
__overlay__ {
/* needed to avoid dtc warning */
#address-cells = <1>;
#size-cells = <0>;
can0: mcp2515@0 {
reg = <0>;
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&can0_pins>;
spi-max-frequency = <10000000>;
interrupt-parent = <&gpio>;
interrupts = <25 0x2>;
clocks = <&can0_osc>;
__overrides__ {
oscillator = <&can0_osc>,"clock-frequency:0";
spimaxfrequency = <&can0>,"spi-max-frequency:0";
interrupt = <&can0_pins>,"brcm,pins:0",<&can0>,"interrupts:0";
I am not sure, because the mcp2515 runs quite good for a while and then suddenly doesn´t receive messages anymore.
Thanks!
