tohox
Unmount/Mount systematically sets dirty bit
Wed Jan 25, 2017 3:20 pm
I'm using a Python script to automate a timelapse. My script periodically switches the DSLR to mass storage mode in order to offload its SD card onto the Pi. To achieve this the Pi has to mount and unmount the volume frequently. I noted the other day that the dirty bit was set on the camera's SD card so I ran fsck which simply reported that the dirty bit was set and that it was automatically removed. I then proceeded to manually unmount and remount the volume to check if my script was causing this behaviour but the dirty bit was set again. I tried the cycle below a couple times and each time the dirty bit gets set after unmounting/remounting:
sudo mount /dev/sdb1 /media/GX7
sudo fsck -a /media/GX7
At this point fsck reports the dirty bit was set and automatically removed so I run it once more to confirm.
This time fsck reports no problems so I unmount and mount to check again...
sudo umount /media/GX7
Dirty bit is set again...
EDIT: I just tried the same routine as above but through a USB SD card reader instead of the camera and got the same result. Repeated the same test with a different SD card also with the same result. Tried again on a different Pi although with the same OS version (Jessie with Pixel) and again the dirty bit is always set.
There doesn't seem to be any consequences other than the annoying warning but I'm wondering if anyone has experienced a similar problem?
Thanks,
tohox
Re: Unmount/Mount systematically sets dirty bit
Wed Jan 25, 2017 8:57 pm
So in principle unmounting the volume should clear the dirty bit as long as it wasn't set before mounting it in the first place but that doesn't seem to be the case here.
Thanks for the link!
tohox
Thu May 18, 2017 2:37 am
Just bumping this post as I still haven't found a valid explanation as to why the dirty bit gets set by simply mounting and immediately unmounting an SD card under Raspbian...
Thanks,
scruss
Thu May 18, 2017 2:52 am
Use mount -o ro to read the device
tohox
Thu May 18, 2017 3:13 am
Scruss,
Indeed but what if I need to erase some files on the SD card before unmounting it? I assume I should be able to do this without setting the dirty bit if done correctly...
Thanks,
Thu May 18, 2017 3:50 am
Have you checked whether that SDCard is worn out? When they reach the end of their usable life the SDCard goes into read only mode and if the dirty bit was set at that time it would stay set for ever.
Are you able to create a new file on it that doesn't disappear after a umount/mount sequence of commands?
Also try
sudo -i
for i in /dev/sda1 /dev/sda2; do umount $i; fsck -f -y $i; done
exit
Because the GUI includes an automounter and that may have mounted the SDCard on /media/pi/xxxxxx directories. If you pull the card while those things are still mounted then you will set the dirty bit.
EDIT: brain dead moron error. Left the testing echos in the command.
This is a doctor free zone.
tohox
Thu May 18, 2017 5:00 am
Hi Dougie,
SD card is not worn out (yet) as it is currently getting written to a couple thousand times a day by the camera and files are still there after unmounting/mounting. Also as mentioned above I've verified this same behaviour with both a different card and a different Pi.
I'm running with X disabled and can confirm that nothing gets automatically mounted under /media/pi. I have however configured fstab so that it mounts the SD card automatically based on its UUID like so:
UUID=5FC6-EB2A  /media/GX7      vfat    defaults,nofail 0       0
Is something wrong with this method? Could this perhpas be a vfat specific issue?
I've modified your suggested test a bit as my card is actually getting mounted at /dev/sdb1 and not /dev/sda1 or /dev/sda2 (sda1 is already used by another disk). Unfortunately it yields no output besides the commands themselves:
[email protected]:/media $ sudo -i
[email protected]:~# for i in /dev/sdb1 /dev/sdb2; do echo umount $i; echo fsck -f -y $i; done
umount /dev/sdb1
fsck -f -y /dev/sdb1
umount /dev/sdb2
fsck -f -y /dev/sdb2
[email protected]:~# exit
logout
However if I run it without the for loop I get:
[email protected]:/media $ sudo umount /dev/sdb1
[email protected]:/media $ sudo fsck -f -y /dev/sdb1
fsck from util-linux 2.25.2
fsck.fat 3.0.27 (2014-11-12)
/dev/sdb1: 28 files, 846/474368 clusters
But upon remounting the card the dirty bit appears set again...
I've also verified the volume was not used by any process before unmounting it with:
[email protected]:/media $ sudo fuser -v /media/GX7
                     USER        PID ACCESS COMMAND
/media/GX7:          root     kernel mount /media/GX7
Can anyone try mounting and unmounting a known good vfat SD card on Raspbian Jessie and report if they also get the dirty bit set upon remounting despite having cleared it previously?
Thanks,
Thu May 18, 2017 5:05 am
Sorry I'm a moron. I left the "echo" commands in (because I didn't want to unmount anything on my RPi that's currently a 10 and a half hour flight away from where I am right now).
sudo -i
exit
tohox
Thu May 18, 2017 5:36 am
[email protected]:~/timelapse $ sudo -i
[email protected]:~# for i in /dev/sdb1 /dev/sdb2; do umount $i; fsck -f -y $i; done
Free cluster summary uninitialized (should be 473522)
  Auto-setting.
Performing changes.
umount: /dev/sdb2: mountpoint not found
e2fsck 1.42.12 (29-Aug-2014)
fsck.ext2: No such file or directory while trying to open /dev/sdb2
Possibly non-existent device?
Same result after remounting, still dirty...
Btw, I couldn't find anything regarding the -f parameter you are using with fsck above. What does it do?
Sun May 21, 2017 2:42 pm
You've got a NOOBS system
so you'll need to check /dev/sdb1 /dev/sdb5 and /dev/sdb6 (maybe more if you have more than one OS).
sameenashaikh29
Thu Mar 08, 2018 12:09 pm
Have you found the solution. I am doing something similar to this
scruss
Thu Mar 08, 2018 1:19 pm
Can you use PTP mode instead? That way the camera manages its filesystem, so you never have to explicitly mount the SD card under Linux.
n67
Thu Mar 08, 2018 1:23 pm
That site could use some editing...
"L'enfer, c'est les autres"
Epmu Sn!
tohox
Thu Mar 08, 2018 2:08 pm
Unfortunately sameenashaikh29, in the end I simply ignored the dirty bit... Been working OK despite this.
scruss
Thu Mar 08, 2018 8:39 pm
Yeah, it was the only PTP and linux site I could find quickly. gphoto does PTP control.
Return to “Raspbian”
