dan.massey
Raspi + c920 to YouTube Live
Tue Jan 24, 2017 4:25 am
Hi everyone - I'm trying to use ffmpeg to stream output from a c920 webcam to YouTube live on a Raspberry Pi.
I am not reencoding the video, I am copying the h264 output from the camera directly to the stream (and mixing in empty audio).
Unfortunately, YouTube Live returns this error when I start the stream:
Please use a keyframe frequency of four seconds or less. Currently, keyframes are not being sent often enough, which will cause buffering. The current keyframe frequency is 9.9 seconds.
For what it's worth, the stream works on Twitch, but buffers pretty frequently.
I am looking for advice to make the stream acceptable to YouTube Live by adjusting the keyframe frequency. Thanks in advance for your help :D
The command I am using is this:
    ffmpeg -ar 44100 -ac 2 -acodec pcm_s16le -f s16le \
    -i /dev/null -ac 2 -f v4l2 -codec:v h264 -framerate 30 -video_size 1920x1080 \
    -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v copy -codec:a aac -ab 128k -g 10 \
    -f flv -strict -2 rtmp://a.rtmp.youtube.com/live2/STREAM_KEY
When I run the command, I get output like:
    ffmpeg version N-60774-gc427b2b Copyright (c) 2000-2014 the FFmpeg developers
      built on Feb 20 2014 16:29:13 with gcc 4.7.1 (crosstool-NG 1.15.2) 20120402 (prerelease)
      configuration: --enable-cross-compile --cross-prefix=/opt/tools/arm-bcm2708/arm-bcm2708hardfp-linux-gnueabi/bin/arm-bcm2708hardfp-linux-gnueabi- --arch=armel --target-os=linux --prefix=/home/jon/arm --enable-gpl --enable-libx264 --enable-nonfree --extra-cflags=-I/home/jon/arm/include --extra-ldflags=-L/home/jon/arm/lib --extra-libs=-ldl
      libavutil      52. 65.100 / 52. 65.100
      libavcodec     55. 52.102 / 55. 52.102
      libavformat    55. 33.100 / 55. 33.100
      libavdevice    55. 10.100 / 55. 10.100
      libavfilter     4.  1.103 /  4.  1.103
      libswscale      2.  5.101 /  2.  5.101
      libswresample   0. 17.104 /  0. 17.104
      libpostproc    52.  3.100 / 52.  3.100
    Guessed Channel Layout for  Input Stream #0.0 : stereo
    Input #0, s16le, from '/dev/null':
      Duration: N/A, bitrate: 1411 kb/s
        Stream #0:0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
    Input #1, video4linux2,v4l2, from '/dev/video0':
      Duration: N/A, start: 80888.938908, bitrate: N/A
        Stream #1:0: Video: h264 (Constrained Baseline), yuvj420p(pc), 1920x1080 [SAR 1:1 DAR 16:9], -5 kb/s, 30 fps, 30 tbr, 1000k tbn, 60 tbc
    Output #0, flv, to 'rtmp://a.rtmp.youtube.com/live2/vktg-95zk-96fm-133h':
      Metadata:
        encoder         : Lavf55.33.100
        Stream #0:0: Video: h264 ([7][0][0][0] / 0x0007), yuvj420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, -5 kb/s, 30 fps, 1k tbn, 1000k tbc
        Stream #0:1: Audio: aac ([10][0][0][0] / 0x000A), 44100 Hz, stereo, fltp, 128 kb/s
    Stream mapping:
      Stream #1:0 -> #0:0 (copy)
      Stream #0:0 -> #0:1 (pcm_s16le -> aac)
    Press [q] to stop, [?] for help
    [flv @ 0x2c0b3d0] Non-monotonous DTS in output stream 0:0; previous: 500, current: 333; changing to 500. This may result in incorrect timestamps in the output file.
    [flv @ 0x2c0b3d0] Non-monotonous DTS in output stream 0:0; previous: 500, current: 369; changing to 500. This may result in incorrect timestamps in the output file.
    [flv @ 0x2c0b3d0] Non-monotonous DTS in output stream 0:0; previous: 500, current: 401; changing to 500. This may result in incorrect timestamps in the output file.
    [flv @ 0x2c0b3d0] Non-monotonous DTS in output stream 0:0; previous: 500, current: 433; changing to 500. This may result in incorrect timestamps in the output file.
    [flv @ 0x2c0b3d0] Non-monotonous DTS in output stream 0:0; previous: 500, current: 469; changing to 500. This may result in incorrect timestamps in the output file.
    frame=  202 fps= 18 q=-1.0 size=     760kB time=00:00:13.94 bitrate= 446.4kbits/s
This github issue https://github.com/raspberrypi/linux/issues/593 suggests there's a control in v4l2-ctl to adjust the keyframe rate, but I don't see it available:
    $ v4l2-ctl --list-ctrls
                         brightness (int)    : min=0 max=255 step=1 default=-8193 value=128
                           contrast (int)    : min=0 max=255 step=1 default=57343 value=128
                         saturation (int)    : min=0 max=255 step=1 default=57343 value=128
     white_balance_temperature_auto (bool)   : default=1 value=1
                               gain (int)    : min=0 max=255 step=1 default=57343 value=255
               power_line_frequency (menu)   : min=0 max=2 default=2 value=2
          white_balance_temperature (int)    : min=2000 max=6500 step=1 default=57343 value=2294 flags=inactive
                          sharpness (int)    : min=0 max=255 step=1 default=57343 value=128
             backlight_compensation (int)    : min=0 max=1 step=1 default=57343 value=0
                      exposure_auto (menu)   : min=0 max=3 default=0 value=3
                  exposure_absolute (int)    : min=3 max=2047 step=1 default=250 value=666 flags=inactive
             exposure_auto_priority (bool)   : default=0 value=1
                       pan_absolute (int)    : min=-36000 max=36000 step=3600 default=0 value=0
                      tilt_absolute (int)    : min=-36000 max=36000 step=3600 default=0 value=0
                     focus_absolute (int)    : min=0 max=250 step=5 default=8189 value=0 flags=inactive
                         focus_auto (bool)   : default=1 value=1
                      zoom_absolute (int)    : min=100 max=500 step=1 default=57343 value=100
dan.massey
Re: Raspi + c920 to YouTube Live
Thu Jan 26, 2017 6:28 am
I managed to get it to work on YouTube Live with the following command:
ffmpeg -re -ar 44100 -ac 2 -acodec pcm_s16le -f s16le -ac 2 -i /dev/zero -f v4l2 -input_format h264 -i /dev/video0 -codec:v copy -acodec aac -ab 128k -g 50 -strict experimental -f flv rtmp://a.rtmp.youtube.com/live2/REMOVED
I can set the resolution by doing:
v4l2-ctl --device=/dev/video0 --set-fmt-video=width=1280,height=720
The ffmpeg output looks like this:
Stream #1:0: Video: h264 (Constrained Baseline), yuvj420p(pc), 320x240 [SAR 1:1 DAR 4:3], -5 kb/s, 30 fps, 30 tbr, 1000k tbn, 60 tbc
Eventually YouTube complains about keyframes, but it manages to maintain a decent stream at 1080p.
