Thu Sep 13, 2012 9:45 am
First of all SD cards dont have 100k write life (maybe there are some very expensive SLC ones), but more like 10k or even less, when newer generation memory is used (for example 2xnm TLC flash is only good for like 750 rewrites).
But not all is bad though. Since most if not all of the sdcards use some kind of wear leveling, that means all cells will be used up evenly, no matter where you physically write stuff (for example on the begging of the partrition).
So to increase the life of sd card, buy as big card as you can (so more data can be writen on it before it dies) and possibly buy a fast card, since these tend to use better MLC flash.
Also use ext2 fs which also writes less to card.
+°´°+,¸¸,+°´°~ Everyone should have a taste of UK Raspberry Pie =D ~°´°+,¸¸,+°´°+
Rasberry Pi,
SoC @ 1225Mhz
256MB Ram @ 550Mhz,
16GB SD-Card,
Raspbian
