DidaJI
After upgrade I have problem with 2560x1440x60hz resolution
Thu Jan 19, 2017 1:08 pm
After rpi-update Jessie (monday) me stopped working HDMI resolution 2560x1440 at 60 Hz.
I use this one settings in config.txt:
disable_overscan=1
init_emmc_clock=100000000
framebuffer_swap=0
hdmi_group=2
hdmi_mode=87
hdmi_cvt=2560 1440 60 3 0 0 1
max_framebuffer_width=2560
max_framebuffer_height=1440
hdmi_pixel_freq_limit=400000000
Now I must set only 41Hz (hdmi_cvt=2560 1440 41 3 0 0 1), with higher frequency that does not work.
Does anyone know how to fix it?
dom
Re: After upgrade I have problem with 2560x1440x60hz resolut
Tue Jan 31, 2017 5:50 pm
Can you test with latest rpi-update firmware? Hopefully this is fixed.
DidaJI
Thu Feb 02, 2017 8:07 am
Thank you very much again Dom, after last rpi-update it's alright.
Now again I'm going on resolution 2560x1440x60Hz.
raspberrybeginner
Tue Jun 06, 2017 2:39 pm
Hello, I have a similar problem.
My monitor is a Lenovo LT3053p with 2560x1600 @60Hz and my RaspberryPi is v3.
My config.txt is the following and the Monitor shows two black bars, left and right.
hdmi_cvt=2560 1600 60 5
hdmi_drive=2
hdmi_group=2
hdmi_mode=87
hdmi_force_hotplug=1
config_hdmi_boost=4
#overscan_left=24
#overscan_right=24
#overscan_top=16
#overscan_bottom=16
disable_overscan=1
max_framebuffer_height=1600
#hdmi_pixel_freq_limit=260000000
arm_freq=900
gpu_mem=512
I allready tried different hdmi_modes but without any changes, I also changed the Hz to 75 or 50 or 41 etc. Please help me.
dom
Wed Jun 07, 2017 1:20 pm
@raspberrybeginner
Running "sudo vcdbg log msg" provides a clue:
000694.556: hdmi: HDMI:EDID filtering out DMT format: 2560x1600p @ 60 Hz (87) with pixel clock 348 MHz and hfp:192 hs:280 hbp:472
The very high resolution requires an overclock of pixel frequency.
Try adding (without the comment "#")
hdmi_pixel_freq_limit=350000000
cwacha
Re: After upgrade I have problem with 2560x1440x60hz resolution
Thu Jan 04, 2018 2:14 pm
Just wanted to mention that I got this to work on my Raspberry Pi 3. I added the following lines to my vanilla installation:
/boot/config.txt
hdmi_mode=87 # (was 82 previously)
I don't care for the framebuffer size so I left away the following settings:
Works like a charm on my HP ZDisplay Z27i.
Cheers
Clemens
