mikeyt13
Firefox ESR update
Thu Jan 19, 2017 5:07 am
Hey Everyone, as you can see by my title I'm having some issues installing Firefox-ESR on my RPi 3 B+, when I go to the terminal and enter
>>> sudo apt-get install iceweasel
it starts the downloading process ask me if I would like to continue with installing since it needs so many Mb's, so I enter Y, than an error appears and says
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main firefox-esr armhf 45.5.0esr-1~deb8u1
404 Not Found [IP: 2001:41c9:1:3ce::11 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main iceweasel all 45.5.0esr-1~deb8u1
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found [IP: 2001:41c9:1:3ce::11 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u1_all.deb 404 Not Found [IP: 2001:41c9:1:3ce::11 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Can anyone tell me what's wrong with the install and how can I fix it Thanks
Re: Firefox ESR update
Sat Jan 21, 2017 11:25 am
mikeyt13 wrote:Hey Everyone, as you can see by my title I'm having some issues installing Firefox-ESR on my RPi 3 B+, when I go to the terminal and enter
It would appear you did not run apt-get update first or have a fully updated Raspbian Jessie with Pixel Operating System:
code]sudo apt-get update
sudo apt-get dist-upgrade
sudo reboot[/code]
https://www.raspberrypi.org/blog/introducing-pixel
