Edoardo
resize sd-card partition (PI- Zero)
Tue Jan 17, 2017 12:03 pm
I've a problem to i want to resize the sd card partition because it is too small, I tried all the possible methods but no one works (sudo raspi-config says - sh sudo:not found same for raspi-config) can you help me
I'm using a pi zero...
Re: resize sd-card partition (PI- Zero)
Sun Jan 22, 2017 10:57 am
Edoardo wrote:I've a problem to i want to resize the sd card partition because it is too small, I tried all the possible methods but no one works (sudo raspi-config says - sh sudo:not found same for raspi-config) can you help me
Welcome, what did you actually install on the SD Card ???? Did you use NoobS ???
Return to “Other”
