marl_scot
Use PI as a bluetooth hub / audio multiplexer?
Tue Jan 17, 2017 7:47 pm
Has anyone herd of using a raspberry pi to combine several BT audio input/outputs into a single BT connection (eg, BT headset and mic)?
Basically I have a couple of machines, a mobile and a VOIP phone, I would like to have all of them connect to a PI and then have one headset and mic connected via BT to the PI as well.
Idea being that a single headset/mic can be used across all the devices. I have a set of BT headphones that can connect to 2 devices, but no more.
Maybe have a set of switches to pick the source, but some form of automatic switching would be better where i can set the VOIP & phone to override any others, and then PC1 to have a higher priority than PC2 etc.
Marl
Douglas6
Re: Use PI as a bluetooth hub / audio multiplexer?
Tue Jan 17, 2017 11:13 pm
It would be a challenge, at best. Problem 1 would be to interface a (bidirectional) handset with the Pi. Problem 2 would be transferring audio from one Bluetooth stream to another. I'd be concerned about audio degradation even if I knew how to do it. Then there's the problem of switching between multiple streams, that might be the easiest to overcome with PulseAudio.
Tafary94
Fri Mar 24, 2017 12:56 pm
I whant to do exactly the same (voip & phone). Did you start something or found another solution ?
