Over Christmas I made my first Pi project and thank you for the advice then. I made a switch and relay circuit so I could control my garden water feature and lighting. This weekend I have moved from the workbench to garden and suddenly my circuit which was working perfectly is no longer working.
Problem 1.
I am using 4 relays.
Relay 1 - Water Feature Motor
Relay 2 - Wall lights (compact fluorescent - 2 pin and ballast therefore inductive)
Relay 3 - Decking lighting (compact fluorescent - 2 pin and ballast therefore inductive)
Relay 4 - Feature lights (LED's)
I am using 5 scene switches.
Switch 1 - Water feature on/off
Switch 2 - Wall lights on/off
Switch 3 - Wall and Decking lights on/off
Switch 4 - All lights on/off
Switch 5 - Everything off
When I use switches 1, 4 or 5 then everything works as programmed.
When I use switches 2 or 3 then I sometimes get the effect I desire and other times I do not. I thought I had read somewhere on here or the web about using some suppression on the load side of the relay to calm down the inductive load but for the life of me I cannot now find that. I have tried swapping the LED and Inductive loads to different relays and the problem is always on the inductive load relays. When I hit switch 3 I immediately get both the wall and decking relay on but then one or the other or both then switch off.
Below is a picture of my bench set up where the led's became relays via the Kuman 8 channel relay board. https://www.amazon.co.uk/Kuman-Channel- ... nnel+relay
Problem 2.
The switching seems fine when I use locals leads to the Pi at the box of tricks in my garden. However once I use the 20m's of CAT5 from the Pi to the switch in the kitchen I get all sort of false triggers. This I think I can sort with some external pull up resistors rather than the internal ones I am using at the moment and so I will sort that after I have sorted the inductive load problem.
Any help appreciated.
Andrew
