xl97
Raspberry Pi LCD - 7" NON-Touchscreen?
Fri Jan 13, 2017 3:14 am
Is there a NON-touchscreen version of the Official RaspberryPi (Pi Foundation) 7" HMDI display?
Like this one:
https://www.sparkfun.com/products/13733
or
https://www.adafruit.com/products/2718
*(not sure why the almost $15.00 difference though)..
BUT NOT a touchscreen? (and perhaps being not a touchscreen, cheaper then?)
Lastly... is the 'black bezel' around/over the screen.. the actual 'touchscreen' portion of the product?
I believe the black bezel makes it over 7" now?
thanks! :D
Re: Raspberry Pi LCD - 7" NON-Touchscreen?
Fri Jan 13, 2017 12:09 pm
xl97 wrote:Is there a NON-touchscreen version of the Official RaspberryPi (Pi Foundation) 7" HMDI display?
Like this one:
or
thanks! :D
There is no non-touch Official Screen.
Maybe this will suffice ? http://www.neosecsolutions.com//product ... 8&cPath=21
The information is out there....you just have to let it in.
My other Linux machine is a ChromeBox
xl97
Fri Jan 13, 2017 5:20 pm
Thanks for the reply!..
The display looks great.., except for the oversized PCB its mounted to.. (wont fit my application/project then) :(
But it was a +5v powered display which is what I was/am looking for.
Can the black bezel on the touch screen be removed? (and if so.. does this then disable/break the touch capabilities?)
And other +5v 7" displays out there? (sorry, having only ever played with Arduino based stuff.. HDMI displays were never an issue! haha).. so this is new territory for me.
All feedback/communication on this topic welcome!.
thanks!
xl97
Sat Jan 14, 2017 2:50 am
What about this:
https://www.adafruit.com/products/1933
Pros?
Cons?
Not sure about the driver board?
Says +5v?
Looks to be same size as official HMDI Pi display.. MINUS the front bezel/touch screen portion?
Anyone use these before by chance?
tinylcd
Sat Jan 14, 2017 10:05 am
hello
are you looking for something similar
http://www.tinylcd.com/tiny149/product. ... product=73
regards
tinylcd
xl97
Sat Jan 14, 2017 4:45 pm
tinylcd wrote:hello
regards
tinylcd
thank you for the reply...
It looks darn close! (no clue on the price of it though?)
The only things I cant make out are:
1.) Does the back PCB extend past the monitor/display edges??
2.) Does the RPi have to stick out so far form the side/back? I have a limited space in my project and would like to keep things to 7" wide...
runs on the +5v from the RPi lines.... as well.
This one looks to have better resolution than the on e linked to above??.. How will that work when using RetroPie? (any issues I need to know about?)
Does the RPi have to mount in that specific area on the back? (ie: is it matching up with some header pins or something? or can it be relocated/mounted elsewhere?
thanks!
