eladbar wrote:i need help in determining what equipment i need for Rasberry PI with several sensors on it :
Gyro & accelometer, Altitude, distance, presure, temprature, GPS, Heading/compass.
memory component and Low Bluetooth Energy component.
What do you mean by "distance"? Distance from what?
The SenseHAT has gyro&accel, barometric pressure for altitude and air pressure, two temperature sensors and a magnetometer for heading/compass.
The Pi has RAM memory and needs an SD card to run which can be used for long term storage. You can suppliment this with a USB storage device, a USB hard drive or even network/cloud storage.
The Pi 3 has a built in bluetooth module but I'm not sure whether it supports the lower energy specifications.
