hdmi_group=1Code: Select all
hdmi_group=2For testing purposes i put in the good old
hdmi_timings=<h_active_pixels> <h_sync_polarity <h_front_porch> <h_sync_pulse> <h_back_porch> <v_active_lines> <v_sync_polarity> <v_front_porch> <v_sync_pulse> <v_back_porch> <v_sync_offset_a> <v_sync_offset_b> <pixel_rep> <frame_rate> <interlaced> <pixel_freq> <aspect_ratio>Now i need to use Edid storage in the display driver.
I made my own edid file and programmed it with another compute module to the storage.
The edid file just contains the general settings and one detailed timing mode. In this i filled in the same data as in the
hdmi_timings=...However, the screen remains white, wich means the timings are not correct or there is no display output from the Rpi (input).
If i build up an development envoirement to be able to access the compute module over ssh, is there any possibility to view something like a logfile to see, why it is not displaying the resolution described in the edid?
Has anybody experiance yet with custom resolutions in the edid?
I hope for mercy, as this is my first post and my english is bad.
