Zalkiaent
reinstalling raspbian on the same sd card?
Tue Jan 10, 2017 5:37 pm
My raspberry pi 2 will not boot right, and the idiot I was, put it on automatic boot.
I don't have any more sd cards, so I need to reinstall the os on the same sd card.
If anyone can help me out here, It would mean a lot.
Thank you! :D
-Zalk
B.Goode
Re: reinstalling raspbian on the same sd card?
Tue Jan 10, 2017 5:47 pm
Easy!
Just imagine that microSD card had never been used with a Raspberry Pi before.
Visit https://www.raspberrypi.org/downloads/raspbian/ and download
RASPBIAN JESSIE WITH PIXEL
Follow the linked document to install it. https://www.raspberrypi.org/documentati ... /README.md
That's all. (Installation from a . img file automatically destroys the previous content and formatting of the card and gives you a clean freshly installed OS - no other preparatory steps are needed.)
Of course, any configuration, scripts or other work you have saved on the microSD card will also be destroyed as part of the same process.
syrisara
Tue Jan 10, 2017 7:57 pm
What Windows version do you use?
In short,
Go to command prompt, Windows.
Type diskpart
Type list disk
See what disk is the sdcard to burn image on. Example disk 4.
Type select disk 4
Be sure you now have the right disk selected. Again be sure! You will get no warning.
Type clean
Type exit
Your sdcard is now without partitions.
Download sdformat. Or use Windows.
Select your disk and format.
Now use win32diskimager to burn your new image.
Hope this helps.
B.Goode
Tue Jan 10, 2017 9:08 pm
Why are the preceding steps necessary? After 5 years of user experience the Raspberry Pi Foundation don't seem to feel it is something they should include in their documentation.
Zalkiaent
Sat Jan 14, 2017 5:59 pm
B.Goode wrote:Easy!
Thank's, I am gonna give this a shot!
Zalkiaent
Sat Jan 14, 2017 9:12 pm
B.Goode wrote:Easy!
It work's! Thank's for the help!
:D
B.Goode
Sat Jan 14, 2017 9:26 pm
Well done.
All I did was point you to the 'official' documentation by the Raspberry Pi Foundation...
yeej2
Wed Sep 11, 2019 5:39 pm
Easy!
If I have a minecraft server on mine, would it delete everything my friends and I have done on the game?
B.Goode
Wed Sep 11, 2019 8:25 pm
Easy!
That would come under the heading of "any configuration, scripts or other work you have saved on the microSD card will also be destroyed as part of the same process."
So Yes, everything previously on the microSD card will be deleted.
Of course, since you have resurrected a topic nearly three years old, the advice to download and install Raspbian Jessie is no longer appropriate as that OS has been twice superceded. At the time of writing in September 2019 the current supported Raspberry Pi Operating System is Raspbian Buster.
Andyroo
Wed Sep 11, 2019 8:37 pm
I would also add that formatting the SD card does nothing but wear it out faster :lol:
With Etcher the partition table and format are all overwritten in one step :D
HawaiianPi
Wed Sep 11, 2019 8:46 pm
Yes. Writing a new image will overwrite anything previously on the card (your server and all related data will be gone). You should get a new SD card and write Raspbian to that, then copy your Minecraft folder and any other data or scripts your server needs from the old card to the new one.
