mikerr
Pi Card Imager - android app prepares SD cards without PC
Mon Jan 09, 2017 2:31 pm
Android app to prepare SD cards for Raspberry - NO PC needed !
You can go from blank card to working raspberry pi without touching your "big" PC or Mac,
downloading & imaging all done on the phone.
[update] downloads while unzipping / extracting - so NO local storage needed on phone
Say goodbye to etcher and win32diskimager !
Image Image Image Image
Features:
- Prepare NOOBS/ Raspbian / KODI / Ubuntu SD cards direct on phone
- Writes images to SD Card direct from zip file
- Backup SD Card into .img file (also zipped to save space)
Can setup SD cards without needing root
Device only needs to be rooted if you want to use custom .img files (reading and writing).
Can use the internal SD slot, but it's better to use an USB OTG lead and card reader.
Get it for free on google play:
https://play.google.com/store/apps/deta ... cardimager
Anyway, comments and requests welcome !
mikerr
Re: Raspi Card Imager - android app prepares SD cards withou
Wed Jan 18, 2017 4:17 pm
Added in OSMC and LibreELEC (kodi)
- which for some reason are distributed as .gz files instead of zip - so needed specific coding
(the app unzips on-the-fly while writing to save space on the phone)
Ubuntu isn't on there yet for similar reason - it's distributed in .xz format
An example of speed, I was able to get fully working OSMC (kodi) on SD in 3 mins including download !
Jessie Lite in under 10 mins: 4 min download / 5 minute to write to SD (around 4 meg/sec)
[edit] now downloads/unzips on the fly - so twice as quick... 5 mins total.
All on the phone without needing a PC...
mikerr
Sun Jan 29, 2017 11:47 pm
Added ability to write/stream a full NOOBS SD card while downloading the zip file
- so no longer needs 1GB storage on the phone.
Seems less users have rooted phones than I thought though - so I'll have to make rooted features (reading/writing .img files) less prominent...
BMS Doug
Mon Jan 30, 2017 1:31 pm
mikerr wrote:Added ability to write/stream a full NOOBS SD card while downloading the zip file
I've never had anything that I needed to root an android phone for, perhaps that situation has now changed.
Doug.
Wattie
Tue Jan 31, 2017 4:03 pm
Excellent idea and thanks for the effort!
Unfortunately I can't seems to find it through a google play search, and if I use your link I get "No eligible devices for app install", despite having three possible OTG options.
bensimmo
Tue Jan 31, 2017 4:35 pm
Very few people would have a rooted phone or tablet, it's not the norm. Just few enthusiasts in reality.
I rooted some a few years back to play with but now I wait out warranties and they would only get routed after that if support for them was no longer available. Still i'd not root if it didn't need it to put a new rom on.
B.Goode
Tue Jan 31, 2017 5:43 pm
Wattie wrote:Excellent idea and thanks for the effort!
Do your devices meet the minimum Android version requirements?
Wattie
Wed Feb 01, 2017 7:57 am
:roll: Weird behaviour by google play. Apparently not available in my country. Perhaps I should step across a border. :/
mikerr
Wed Feb 01, 2017 9:40 am
Which country? I thought it was set for worldwide - I'll re- check settings.
[edit] should be ok now - language settings were English only
Wattie
Wed Feb 01, 2017 10:57 pm
Switzerland.
I get different messages depending which angle I approach, but this was from your link when already using Android and logged into Google.
If I click the link from a Windows 10 machine, I get the "no devices". Surely an HTC A9 with marshmallow would be eligible?
Searching from the top of Google Play when logged in fails to find the app on any device.
And of course (beside the point) it's not possible to approach Google Play logging in on a PC if you don't speak fluent German, because, well, that's where you are isn't it?
Just one route to the goal would be great.
Thanks Mike
Edit to mirror your edit: Yep, it works now - weird behaviour from google, but languages have been causing strange logic since the internet blew up; 'specially with those chaps.
mikerr
Tue Feb 07, 2017 3:12 pm
Currently the list of Images this can install without root is:
NOOBS, PINN and BerryBoot
(i.e. all fat32 based)
Raw disk images (.img) need root access.
I've just noticed that OSMC, despite being distributed as a disk .img actually extracts to a single fat32 partition, and the pi does a NOOBS-style install
So if just those files were repackaged into a zip file, the app could then create OSMC SD cards without root.
[edit] so close - OSMC install is missing the crucial fat32 resize stage - so its a no go
mikerr
Wed Mar 29, 2017 2:55 pm
New update:
the app can now create LibreELEC (KODI) SD cards without needing root (a much requested feature !)
Note this is perfectly safe as by default it doesn't delete any files already on the SD
ric96
Mon Apr 03, 2017 11:25 am
I have a unrooted motorola g4 plus and i am having trouble writing noobs lite to sdcard via otg.
any idea
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
mikerr
Mon Apr 03, 2017 11:38 pm
At what point are you having trouble, any error messages?
Also it's advisable to unmount the card/usb in android settings before removing it - some devices need that to avoid sd corruption.
mikerr
Thu Apr 13, 2017 10:54 pm
Ubuntu MATE can now be installed without root.
mikerr
Re: Pi Card Imager - android app prepares SD cards without PC
Thu Aug 24, 2017 10:10 pm
Added a NOOBS version of Kali that can now be installed without root,
as can Screenly - digital signage.
jake1130
Mon Aug 28, 2017 2:08 pm
Hey Mike,
Love the app, its been really helpful for me so far.
I'm having an issue though with partitioning when the pi tries to boot my NOOBS Lite install.
NOOBS loads but then gives me an error on the home screen which reads "File system is reporting the free space as 976624 clusters, not 975480 clusters."
I think this might be due to the cache files which android auto-loads on to any external sd card. I have tried unmounting before removing the card but it hasnt made a difference.
For reference, i am running the latest version of android on a galaxy s7.
Have you seen this issue before by chance? Any idea how i could fix it?
Thanks!
Jake
mikerr
Fri Sep 22, 2017 2:40 pm
Sorry for the late reply - but this might help someone else:
I think that error means the FAT32 filesystem is corrupt - usually caused by removing the SD card without safely unmounting first
(you get away with doing that 90% of the time)
Drag down from the notification bar, and select "safely remove mass storage",
or go to android settings/storage/unmount SD/USB card
artificial face
Mon Mar 26, 2018 9:22 pm
Can you make it part of the app to image RetroPie without root? Thanks
Umdasu
Sun Apr 29, 2018 10:46 am
@mikerr
So I'm rooted (sm-j710 running supernova rom v4). Root is superuser and not Magisk. I tried to flash custom images using raspi card imager. Everything available on the raspberry .org site. Lately I'm getting an error no matter what distribution I try.
Error:java.util.zip.Zipextraction: cannot read local header version 45. Thanks in advanced
pjh64
Tue Sep 11, 2018 3:23 pm
This app does make things a lot easier when there is no PC accessible. Worked like a charm. The only thing somewhat disappointing is that Google Play is required to get the APK.
mikerr
Wed Sep 12, 2018 3:16 pm
It is on google play, but that isn't required - the apk is elsewhere as well
e.g. apkfun : https://www.apk4fun.com/apk/89659/
olefrank
Tue Sep 03, 2019 4:46 pm
I'm trying to install a new RPI4 with Raspbian Lite. I need to enable ssh to be able to setup the RPI. Is this possible to do directly on a non-rooted phone (Samsung Galaxy S7)? I tried this:
1. format SD directly on phone
2. DL and write Raspbian Lite to SD
3. put file "ssh" in root of SD (which is automatically called "recovery" by phone)...
4. ssh pi@192.168.1.xxx --> ERROR `ssh: connect to host 192.168.1.119 port 22: Connection refused`
Is this possible to achieve?
Ole
Andyroo
Tue Sep 03, 2019 4:58 pm
You could try putting the file ssh.txt in the folder - make sure it’s all lowercase.
Not sure if this is still valid as it’s been a long time since I used the txt version...
mikerr
Sat Sep 07, 2019 9:03 am
For NOOBS the SSH file method to enable ssh only works on the very first boot (when NOOBS system formats /creates the partitions).
