Ritesh
How to start location display?
Mon Jan 09, 2017 12:57 pm
I want to start building location based display which show location of place .
how should i start?
topguy
Re: How to start location display?
Mon Jan 09, 2017 1:08 pm
Location on a map ? Or as an address ?
Location based on GPS or something else ?
What kind of display ? Any screen/monitor or something specific ?
Ritesh
Mon Jan 09, 2017 1:44 pm
i want to know what we can do?
and can we use screen or lcd 16x2?
topguy
Mon Jan 09, 2017 2:23 pm
I don't know you, what can you do ? ;-)
The Raspberry Pi on the other hand can do (almost) everything. But It's the details that decide if it will be easy/hard and cheap/expensive.
But obviously you will not be able to draw a map on a 16x2 character LCD display.
So if your question boils down to "Can you read a posision from a GPS and show the address of that location on an LCD display." then the answer is yes. ( but with the pre-requisite that is has internet so it can use Googles GeoLocation API )
If you have a screen then you can run full car navigation software if you want.
http://libresmartphone.com/navigation-s ... pberry-pi/
Ritesh
Tue Jan 10, 2017 3:07 pm
hello
how to make map based but it will require internet to download...
