awhite2 wrote:So, maybe this is a really basic question, but I'm trying to install Kali on the same SD card that came preloaded with NOOBS and Raspbian. I've downloaded and extracted the img and tried to put it directly onto the card, but it seems I can't because of the partitions NOOBS has set up. I'd rather not use a different SD.
I saw mentioned somewhere that I could install it by putting it on a flashdrive. Any tips?
You can't add images to an existing NOOBs install without wiping the card and starting over.
Read the Kali web site/forums to find out how to install the image.
Likely the Kali image needs to be written with a copy utility such as Win32diskimager or similar bit copy software. The contents of the card will be lost.
I would suggest to get another SD card(s) to install another OS.
