twocats
Pi4J MCP23017 gives "Failed to select slave device"
Fri Jan 06, 2017 3:47 pm
Hi All,
I have a raspberry B rev2 (revision 000f from /proc/cpuinfo)
I'm running Raspbian GNU/Linux 8 (jessie) kernel 4.4.37+ #936 Fri Dec 9 16:53:10 GMT 2016 armv6l
/boot/config has dtoverlay=mcp23017 (with or without this the error still occurs)
(with the dtoverlay) the MCP23017 device is recognised and is presented to the /sys FS as
/sys/devices/platform/soc/20804000.i2c/i2c-1/1-0020/gpio/gpiochip496
using the example MCP23017GpioExample code - having changed the provider line to:
provider = new MCP23017GpioProvider(I2CBus.BUS_1, 0x20);
when i run
java -cp pi4j-example-1.2-SNAPSHOT.jar:pi4j-core-1.2-20161229.215408-19.jar:pi4j-device-1.2-20161229.215426-19.jar:pi4j-gpio-extension-1.2-20161229.215417-19.jar MCP23017GpioExample
I get the error :
<--Pi4J--> MCP23017 GPIO Example ... started.
Exception in thread "main" com.pi4j.io.i2c.I2CIOException: Failed to select slave device!
	at com.pi4j.io.i2c.impl.I2CBusImpl.selectBusSlave(I2CBusImpl.java:284)
	at com.pi4j.io.i2c.impl.I2CBusImpl.runBusLockedDeviceAction(I2CBusImpl.java:243)
Any thoughts?
Re: Pi4J MCP23017 gives "Failed to select slave device"
Fri Jan 06, 2017 7:59 pm
Is your MCP23017 connected correctly? Have you tied the A0, A1 & A2 pins to GND?
What does i2cdetect -y 1 show?
You may need to use sudo apt-get install i2c-tools to get that program available for you.
twocats
Fri Jan 06, 2017 8:40 pm
Yes its connected correctly - I can control it directly using the /sys filing system.
It will happily read and change the output. Either by just simple command line commands
or via python.
i2c shows this :
i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
which in case the formatting is incorrect shows I have 2 devices - the MCP at address 0x20 and the RTC at 0x68
If on the command line I do
echo 496 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio496/direction
echo 1 > /sys/class/gpio/gpio496/value
sleep 1
echo 0 > /sys/class/gpio/gpio496/value
it will change the output correctly.
likewise I can do the same and it will read correctly.
Fri Jan 06, 2017 9:39 pm
That 'UU' status means the device has been captured by the kernel and isn't available for userspace programs. So if your Java program doesn't use the /sys filesystem interface you'll need to remove that overlay for the MCP23017 and reboot.
The stuff here: https://github.com/Pi4J/pi4j/blob/maste ... ample.java doesn't need the overlay. It uses /dev/i2c-1 driving that with the Java native interface (JNI) code in com_pi4j_wiringpi_I2C.c.
twocats
Fri Jan 06, 2017 11:55 pm
Ace that works!
(I've black listed gpio_mcp23s08 as well for good measure!)
Thanks!
Return to “Java”
