gsourav
Speaker/Mic connected via Bluetooth USB dongle - cant record
Mon Jan 02, 2017 10:38 am
Hi All,
I have a Raspberry pi 2 mod B running Jessie. I have been trying like to build my own "Amazon Echo" like solution using a JBL GO bluetooth speaker (it has a built-in mic too) connected to the pi using a bluetooth USB dongle. So there is no wire from my pi to speaker/mic combo.
When I connect the speaker to my Ubuntu (16.04) laptop I am able to play & record audio with no problems (using arecord & aplay).
When I connect it with my pi, I am able to play using aplay command but unable to record using arecord. alsamixer shows the recording device when I connect the speaker/mic (please see attached screenshot).
My guess is that I am missing some bluetooth driver/config that will tell the system that the bluetooth dongle is connecting 2 (mic & speaker) devices as opposed to one. Not sure though.
I have spend weeks trying to search and resolve with no success and now I have decided to put in this forum in hopes to get help.
Many thanks for taking your time reading and helping me!
Warm regards,
Sourav Gupta
Douglas6
Re: Speaker/Mic connected via Bluetooth USB dongle - cant re
Mon Jan 02, 2017 2:13 pm
In order to play and record over Bluetooth, you would need to enable the HSP/HFP profile on the Pi. I've never seen that done. It would require at least building the latest PulseAudio, and possibly Ofono as well.
gsourav
Mon Jan 02, 2017 5:22 pm
Hi Douglas,
Many thanks for your prompt response. I will probably give it a try and let this forum know about the outcome.
Thanks again.
Warm regards,
Sourav
skyplusplus
Re: Speaker/Mic connected via Bluetooth USB dongle - cant record
Wed Apr 04, 2018 3:47 pm
Hi there... was just wondering if you managed to get it working.
I'm planning to build something similar and wanted to see if i can rely on Bluetooth connectivity dor mic and sound.
gsourav
Wed Apr 04, 2018 8:43 pm
Unfortunately, I have not been able to spend time on this project since then. So it still stays where it was back then. Sorry.
Best of luck for your project. I am sure there have been a lot of progress in this area since then so, if you happen to get it working please let me know. thanks!
