Hi
I've enabled a Pi with SSH on Jessie Lite so I can login remotely. I have changed the port from 22 and enabled logging with SSH keys and then installed fail2ban with it set to ban on 1 failed login attempt.
However fail2ban seems to ignore failed logins attempts without keys, auth.log shows
sshd[739]: Connection closed by IP [preauth]
I understand nobody can log in without the keys, but thought fail2ban would block the port if a failed attempt was made?
I have seen a post elsewhere adding this line to fail2ban ssh filter,
^%(__prefix_line)sConnection closed by <HOST> \[preauth\]$
But I'm not sure if it is wise to add this line or not, as I'd have thought it would have been a default line in the filter anyway. Does anyone have a view on this?
I also noticed that my Jessie Lite installation is using a deb from 2014, fail2ban_0.8.13-1_all.deb. I can see Raspbian has a newer version fail2ban_0.9.6-1_all.deb http://mirrordirector.raspbian.org/rasp ... /fail2ban/ and wondered if the newer fail2ban version might block failed ssh key attempts, but confused as to why it is not available via apt-get. Any ideas?
Thanks in advance
Rich
