Powershell
Fast switching of WIFI networks
Fri Dec 30, 2016 3:27 pm
Hi guys and happy new year!
I travel alot and I always take my Pi 3 with me as a headless server.
To use public hotspots, I need a solution to quickly add SSID and PSK of any new network.
Would it be correct if I somehow do the following:
I put a copy of "/etc/network/interfaces" to a FAT partition of Pi's sdcard.
Take the card out and edit it on my laptop.
When booting, a shell command will "cp -f /boot/interfaces /etc/network" (overwrite)
Will it do, or is there more elegant method? Thanks!
Re: Fast switching of WIFI networks
Fri Dec 30, 2016 10:50 pm
Put all network defs in your wpa_supplicant.conf file and your system will automatically connect to the network in range.
jbudd
Sat Dec 31, 2016 12:20 am
With the current version of Raspbian Jessie you should be managing wifi credentials in /etc/wpa_supplicant/wpa_supplicant.conf.
On bootup it looks for a wpa_supplicant.conf file in /boot (which is writable on your PC). If it finds one, it copies it to /etc/wpa_supplicant/ and deletes the original.
This gives a nice easy way to input the details of new networks:
sudo cp /etc/wpa_supplicant/wpa_supplicant.conf /boot/supplicant.txt
Now on your PC add the new network to the file "supplicant.txt" and copy it as wpa_supplicant.conf
A basic wifi stanza might look like this
network={
        ssid="MuseuDoAmanha"
        psk="CidadeMaravilhosa"
but there are many other parameters available for different network authorisation methods
When you boot the Pi, with a little luck it will connect.
Powershell
Wed Jan 04, 2017 7:12 am
Thanks! That makes sense!
At what stage it is better to invoke this?
