I am not sure but i do believe that i am using WEPDougieLawson wrote:Is your WiFi SSID hidden?
Is your network using WEP (which is 100% insecure and not supported by the GUI)?
Change your Router to WPA, WEP is insecureJwenger17 wrote:I am not sure but i do believe that i am using WEPDougieLawson wrote:Is your WiFi SSID hidden?
I have switched it to WPA 2 but i still cannot connect through my RPI 3fruitoftheloom wrote:Change your Router to WPA, WEP is insecureJwenger17 wrote:I am not sure but i do believe that i am using WEPDougieLawson wrote:Is your WiFi SSID hidden?
It now shows that I have connected however i cannot connect to google or the raspberry help forums through the chromium web browserDougieLawson wrote:Open an lxterminal window and type in these arcane incantations, putting in your ssid / psk as needed.
sudo -i
cd /etc/wpa_supplicant
wpa_passphrase yourSSIDgoeshere passwordforthatSSIDgoeshere >> wpa_supplicant.conf
reboot
ip addr
ip route
sudo ping -c 3 $(ip route|awk '/default/ {print $3}')
sudo ping -c 3 8.8.8.8
sudo ping -c 3 Google.com
cat /etc/resolv.confI used a image to text application to copy over the code I fixed errors but i may have missed onejbudd wrote:Just a small suggested tweek to those commands:(ping will carry on until you interrupt it, ping -c 3 stops after sending 3 packets)Code: Select all
ip addr ip route sudo ping -c 3 $(ip route|awk '/default/ {print $3}') sudo ping -c 3 8.8.8.8 sudo ping -c 3 Google.com cat /etc/resolv.conf
interface wlan1
static domain_name_servers=8.8.8.8 8.8.4.4Is there some reason you can't use simple copy and paste?I used a image to text application to copy over the code I fixed errors but i may have missed one
If by gateway router you mean my ssid it is NNJ25. I do have a verizon router but my personal computer is a mac and the codes you gave me do not translate over into terminal. I am not well versed in any sorts of computer coding so what is set on the raspberry is mostly due to my attempts to follow fix it guides that i have found.DougieLawson wrote:There's an awful lot that's screwy there.
What's the address of your gateway router, because you're missing a route to it?
Is your ISP Verizon? As they own that 108.0.0.0/8 network block.
Can you ping your resolver 71.242.0.12?
Why do you have "search" set to an IP address rather than a domain name?
What does the IP stuff on your Windows machine look like? Take a look with ipconfig /all in a cmd.exe window.
What do you have in /etc/network/interfaces?
What do you have in /etc/dhcpcd.conf?
I have my raspberry connected to a monitor and theres no way to transfer a copy and paste over to my computer. I'm not sure if id be able to open up the os on my laptop so that i would be able to do that. ( again i have a mac so screen capturing is not possible)jbudd wrote:Are you connected to your router?
The nameserver listed in /etc/resolv.conf looks like a Verizon one. I don't know why it isn't working, but you could try adding this to the bottom of /etc/dhcpcd.confEdit - no that won't work since you can't ping 8.8.8.8Code: Select all
interface wlan1 static domain_name_servers=8.8.8.8 8.8.4.4
Your software seems to have read the pipe symbol ( | ) as the digit 1. It's purpose is to take the output of "ip route" and pass it on to another program "awk" for more filtering.
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
