Bimblis
Omxplayer supports 5.1 surround?
Wed Dec 28, 2016 11:50 pm
Omxplayer supports 5.1 surround? (with an USB soundcard, of course).
rpdom
Re: Omxplayer supports 5.1 surround?
Thu Dec 29, 2016 8:13 am
AFAIK omxplayer only supports the native audio interfaces on the Pi - that is the HDMI and the A/V jack socket. Unless something has changed it doesn't support any other audio devices, including USB ones.
ghans
Thu Dec 29, 2016 8:29 am
Newer versions of omxplayer support ALSA and even PulseAudio via PulseAudios ALSA compatibility layer.
That means that omxplayer does support sound over Bluetooth indirectly too.
viewtopic.php?f=66&t=162289#p1050089
ghans
rpdom
Thu Dec 29, 2016 8:52 am
ghans wrote:Newer versions of omxplayer support ALSA and even PulseAudio via PulseAudios ALSA compatibility layer.
Ok cool, I sit corrected ;)
gkreidl
Thu Dec 29, 2016 10:54 am
If your TV / sound system connected to HDMI supports AC3 / DTS decoding you can use the "-p" or "--passthrough" option.
tvservice -a
will tell you if it is supported.
Minimal Kiosk Browser (kweb)
Bimblis
Thu Dec 29, 2016 12:14 pm
With omxplayer, using the option of -o alsa like "omxplayer -o alsa bubles2.wav", is able to send sound through the USB soundcard to the speakers. But the question is if it supports 5.1 surround, because all the 5.1 audio I send through it is downmixed to stereo.
Audio codec pcm_s24le channels 6 samplerate 44100 bitspersample 24
Subtitle count: 0, state: off, index: 1, delay: 0
The same file, with mplayer, uses the speakers correctly in 5.1
mplayer --channels=6 bubles2.wav
gkreidl
Thu Dec 29, 2016 1:38 pm
You could try the
--layout 5.1
option.
Bimblis
Thu Dec 29, 2016 2:42 pm
Interesting. With that option --layout 5.1, the audio file is not downmixed to stereo. The front right and front left speakers play their channel, but the other 4 speakers dont play anything.
From where does omxplayer pick the configuration when doing the -alsa thing?
gkreidl
Thu Dec 29, 2016 3:58 pm
You already asked in the right place: https://github.com/popcornmix/omxplayer/issues/511
Bimblis
Thu Dec 29, 2016 4:11 pm
I guess you looked up in google and discovered my footprints :)
gkreidl
Thu Dec 29, 2016 5:04 pm
Bimblis wrote:I guess you looked up in google and discovered my footprints :)
No, I went directly to the issues.
Return to “Advanced users”
