ferrymanr
Lost overclocking after updates
Mon Sep 10, 2012 8:27 am
Hi
I have for some time had my /boot/config.txt altered to increase clocks and this has worked very well:
arm_freq=900
gpu_freq=250
sdram_freq=500
This morning I ran rpi-update followed by apt-get update and apt-get upgrade. Now the system seems to be back at 700MHz. There seem to be a a number of linesduring boot that seem to rlate to frequencies but I don't understand them.
Is there a change to the way the overclocking should be set up?
RaTTuS
Contact: Twitter YouTube
Re: Lost overclocking after updates
Mon Sep 10, 2012 8:30 am
I've not done an update for a few days however
can you share your updated file [or the relevant bits]
could it be just a currupted config file?
Covfefe
Licaon_Kter
Mon Sep 10, 2012 8:43 am
It happened to me once, did not track it, somehow the config.txt got overwritten.
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
dom
Mon Sep 10, 2012 8:49 am
ferrymanr wrote:Hi
arm_freq=900
gpu_freq=250
sdram_freq=500
Check here:
http://www.raspberrypi.org/phpBB3/viewt ... ng#p169726
Sander
Mon Sep 10, 2012 9:10 am
Licaon_Kter wrote:It happened to me once, did not track it, somehow the config.txt got overwritten.
Overwritten config.txt? I have had strange experiences with config.txt too: after changing it, there were a lot of strange characters in config.txt from the point where I had edited it.
So, easy check: what does "cat /boot/config.txt" look like? Normal, or strange characters / format somewhere?
My work around: shutdown Raspi, put the SD card into another computer, mount it, edit the config.txt file, save it, unmount, and put the SD card back into the Raspi.
HTH
ferrymanr
Mon Sep 10, 2012 9:18 am
Thanks Dom, that explains it all. I run a lot of analysis using FFT which hits the cpu hard. When I first tried overclocking to 900MHz I could not measure any temperature change but fitted heatsinks to both the chips 'just in case'. The supply current only increased by one or two milliamps so I never thought dynamic clocking would be necessary. Perhaps it would be more of a problem with higher overclocking rates. I shall see how it runs over the next few days with the new system.
Richard (Dick) G4BBH
Licaon_Kter
Mon Sep 10, 2012 9:20 am
why not edit it on the Pi itself?
It might get CR/LF "^M" artefacts due to editing it on Windows, if so do use Notepad++
Return to “Raspberry Pi OS”
