1uke_
Help me finish my audio project - To connect speakers do I n
Fri Dec 23, 2016 9:28 pm
I have been working on a multi room audio project.
I now have my Raspberry Pi running Max2Play, but I am wondering how do I go about attaching speakers to my Raspberry Pi?
Do I need to use a DAC, an Amp or both?
Any help, guidance or advice would be gratefully appreciated.
Thanks in advance for your help :)
Re: Help me finish my audio project - To connect speakers do
Sat Dec 24, 2016 8:18 am
1uke_ wrote:Hello,
The Raspberry Pi has Audio Out via the TRRS4 AV Socket, it is line level only so would need amplified speakers:
https://www.raspberrypi.org/documentati ... -config.md
RPi 4B 4GB (SSD Boot)..
james-at-lo-tech
Sat Dec 24, 2016 10:07 am
Audio can also be delivered through HDMI to an amplifier that way. There are also high-quality DAC HATs available, which again would be used to feed an amplifier (or active speakers).
max2play
Wed Mar 29, 2017 10:41 am
Hi 1uke_,
If you are looking to get the best audio out of the Pi with our software, we would recommend using a DAC HAT for active speakers or stereo systems and an Amp HAT for passive speakers to be connected directly to the Pi.
Here is a chart we recently created comparing the different HAT sound cards for the Pi.
OS Developer Account
Visit Max2Play at www.max2play.com
Return to “Media centres”
