Mansome
Setup Auto Start VNC server
Fri Dec 23, 2016 4:22 am
Hi all,
I wanted to know if it is possible to setup a VNC server that auto starts but is not linked to a specific profile that auto logs in. I wanted to change my pi server to be completely headless at this point. I do not want my pi auto logging itself in though. Is that possible with the VNC server? If so is there a guide to set this up for the latest version of the pi?
sconemad
Re: Setup Auto Start VNC server
Fri Dec 23, 2016 5:11 pm
Hi, yes the RealVNC service mode server can do this. This should be installed by default in Raspbian Pixel, and can be enabled via the Raspberry Pi configuration app. Then configure your Pi to boot to desktop but not auto login.
Mansome
Fri Dec 23, 2016 6:35 pm
sconemad wrote:Hi, yes the RealVNC service mode server can do this. This should be installed by default in Raspbian Pixel, and can be enabled via the Raspberry Pi configuration app. Then configure your Pi to boot to desktop but not auto login.
When I do the raspi-config there is no option for VNC. I was thinking that something might have changed.
ElEscalador
Elescalador
Fri Dec 23, 2016 6:53 pm
It might be under advanced options. Make sure you have one of the latest two releases of jessie.
Giving away some sensors and robot parts in advance of my book release! The first review and giveaway below!
https://youtu.be/fCX0HaeQiyw
Mansome
Re: Elescalador
Tue Dec 27, 2016 2:20 pm
ElEscalador wrote:It might be under advanced options. Make sure you have one of the latest two releases of jessie.
Its not under that either. The base image was not the latest Jessie but was upgraded to that. I dont know if that makes a difference.
legendisback
Tue Dec 27, 2016 2:31 pm
Mansome wrote:Hi all,
yes
install tightvncserver
sudo apt-get install tightvncserver
then
tightvncserver
(it will ask for a password use six dig password 666666 for example)
then use autocutsel (copy,paste between computer and pi )
sudo apt-get isntal autocutsel
then
sudo nano /home/pi/.vnc/xstartup
add
autocutsel -fork
after xsetroot –solid grey
then
sudo nano /etc/rc.local
add
su - pi -c   '/usr/bin/tightvncserver  :1'
to the end before exit
then
sudo nano ~/.bashrc
Paste following code at the end.
if [ -z "$XAUTHORITY" ]; then
    if [ -e $HOME/.Xauthority ]; then
        export XAUTHORITY=$HOME/.Xauthority;
     fi;
fi
then a sudo reboot
you are all set
good luck
and i always use sudo because i dont want to get no permission error
I am the terror that flaps in the night...
I am the surprise you find in your cereal box!
I am DARKWING DUCK!!!
sconemad
Re: Elescalador
Tue Dec 27, 2016 4:53 pm
It's moved to the interfacing sub-menu in the latest version.
If you have upgraded, then you may need to manually install the realvnc-vnc-server package.
Mansome
Wed Dec 28, 2016 2:03 pm
yes
then
tightvncserver
then
add
autocutsel -fork
then
add
then
sudo nano ~/.bashrc
     fi;
fi
then a sudo reboot
you are all set
good luck
I notice you use the user pi in this guide, in my install I almost never log in as pi. I created another account that I primarily use. Do I need to change it to that user or keep it as pi?
