Electrodog10
Python CGI running Sudo os.system
Sun Dec 18, 2016 2:37 pm
I'm trying to write a Python CGI script that will execute an executable file in the /usr/local/bin/ folder. It's a compiled C program that is for a legacy tuner. My problem is that the executable file will ONLY run when in sudo because of the libhid library that requires a sudo user.
How can I get this os.system command to run "as sudo" so it works properly?
The code is below. Thanks!
#!/usr/bin/env python
import cgi
import os
form = cgi.FieldStorage() # instantiate only once!
band = form.getfirst('band', 'empty')
freq = form.getfirst('freq', 'empty')
# Avoid script injection escaping the user input
band = cgi.escape(band)
freq = cgi.escape(freq)
bandLower = band.lower()
sysCommand = ("sudo /usr/local/bin/shark -"+bandLower +" " + freq)
os.system(sysCommand)
print("""\
Content-Type: text/html\n
<html><body>
<p>The submitted command was "%s"</p>
</body></html>
""" % sysCommand)
Electrodog10
Re: Python CGI running Sudo os.system
Sun Dec 18, 2016 2:47 pm
Also it works if I run it as a regular Python file, so basically I need to give the "user" running the CGI script the same permissions that the pi user has. I'm using lighttpd for server software.
Thanks!
Sun Dec 18, 2016 3:16 pm
The web server runs as uid=www-data, gid=www-data. It's an exceedingly bad idea to give www-data free use of sudo.
lewiscallaway
Sun Dec 18, 2016 3:22 pm
I know it is bad, but it will be run only on a local network.
How do I give www-data the permissions to execute?
Sun Dec 18, 2016 3:50 pm
Edit your sudoers file with sudo visudo.
Return to “Python”
