toma678
Double DIN Display mounting
Sat Dec 17, 2016 8:17 pm
Hi guys,
Before I go machining out the adapter plate I drew up to fit the official display into a double DIN head unit slot, does anyone know of any full DDIN cages that are pre-made for the official touch screen?
Cheers
antispecies
Re: Double DIN Display mounting
Sat Apr 21, 2018 6:24 am
Hi, I've been searching around and haven't found much. Any chance you have found a decent solution for this?
Cheers
CyberJacob
Wed May 09, 2018 8:45 pm
I'm also looking into this. It appears that the official 7" touch screen is about the right size for a double-DIN unit, but might need the bezel to be trimmed down slightly.
jitto
Fri May 25, 2018 10:45 pm
I made the mistake of trying to trim down the bezel (109 mm) to fit double DIN (101 mm) and ended up breaking the glass. Even with a glass cutter, it is not an easy job. Now I am left with a perfectly working LCD that fits double DIN, but without touch panel :(
Return to “Official Foundation Display”
