Assume I have the following HTML source code:
<img onload="..." ... someotherattr="..." ...> ... </img>
How can I remove the two attributes "onload" and/or "someotherattr" but not all other (possibly existing) attributes?
Can I put the remove command for the two attributes into one statement or do I have to setup two commands (for one attribute per command)?
jQuery can be used if it is simpler
Thank you
Read more at W3schools
