My mistake. Sorry...
The value in alsa.conf is set to 1 because in the last setup, USB card was on 1.
lsusb
Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
cat /proc/asound/cards
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
Aliases.conf:
# These are the standard aliases and dependencies.
# This file does not need to be modified.
# prevent unusual drivers from appearing as the first sound device ###########
options snd-pcsp index=-2
options snd-usb-audio index=-2
options cx88_alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
# work around other kernel issues ############################################
# The EHCI driver should be loaded before the ones for low speed controllers
# or some devices may be confused when they are disconnected and reconnected.
softdep uhci-hcd pre: ehci-hcd
softdep ohci-hcd pre: ehci-hcd
ALSA.CONF
# ALSA library configuration file
# pre-load the configuration files
@hooks [
func load
files [
@func concat
strings [
{ @func datadir }
"/alsa.conf.d/"
"/etc/asound.conf"
"~/.asoundrc"
errors false
# load card-specific configuration files (on request)
cards.@hooks [
func load
files [
@func concat
strings [
{ @func datadir }
"/cards/aliases.conf"
func load_for_all_cards
files [
@func concat
strings [
{ @func datadir }
"/cards/"
{ @func private_string }
".conf"
errors false
# defaults
# show all name hints also for definitions without hint {} section
defaults.namehint.showall on
# show just basic name hints
defaults.namehint.basic on
# show extended name hints
defaults.namehint.extended on
defaults.ctl.card 1
defaults.pcm.card 1
defaults.pcm.device -2
defaults.pcm.subdevice -1
defaults.pcm.nonblock 1
defaults.pcm.compat 0
defaults.pcm.minperiodtime 5000 # in us
defaults.pcm.ipc_key 5678293
defaults.pcm.ipc_gid audio
defaults.pcm.ipc_perm 0660
defaults.pcm.dmix.max_periods 0
defaults.pcm.dmix.rate 48000
defaults.pcm.dmix.format "unchanged"
defaults.pcm.dmix.card defaults.pcm.card
defaults.pcm.dmix.device defaults.pcm.device
defaults.pcm.dsnoop.card defaults.pcm.card
defaults.pcm.dsnoop.device defaults.pcm.device
defaults.pcm.front.card defaults.pcm.card
defaults.pcm.front.device defaults.pcm.device
defaults.pcm.rear.card defaults.pcm.card
defaults.pcm.rear.device defaults.pcm.device
defaults.pcm.center_lfe.card defaults.pcm.card
defaults.pcm.center_lfe.device defaults.pcm.device
defaults.pcm.side.card defaults.pcm.card
defaults.pcm.side.device defaults.pcm.device
defaults.pcm.surround21.card defaults.pcm.card
defaults.pcm.surround21.device defaults.pcm.device
defaults.pcm.surround40.card defaults.pcm.card
defaults.pcm.surround40.device defaults.pcm.device
defaults.pcm.surround41.card defaults.pcm.card
defaults.pcm.surround41.device defaults.pcm.device
defaults.pcm.surround50.card defaults.pcm.card
defaults.pcm.surround50.device defaults.pcm.device
defaults.pcm.surround51.card defaults.pcm.card
defaults.pcm.surround51.device defaults.pcm.device
defaults.pcm.surround71.card defaults.pcm.card
defaults.pcm.surround71.device defaults.pcm.device
defaults.pcm.iec958.card defaults.pcm.card
defaults.pcm.iec958.device defaults.pcm.device
defaults.pcm.modem.card defaults.pcm.card
defaults.pcm.modem.device defaults.pcm.device
# truncate files via file or tee PCM
defaults.pcm.file_format "raw"
defaults.pcm.file_truncate true
defaults.rawmidi.card 0
defaults.rawmidi.device 0
defaults.rawmidi.subdevice -1
defaults.hwdep.card 0
defaults.hwdep.device 0
defaults.timer.class 2
defaults.timer.sclass 0
defaults.timer.card 0
defaults.timer.device 0
defaults.timer.subdevice 0
# PCM interface
# redirect to load-on-demand extended pcm definitions
pcm.cards cards.pcm
pcm.default cards.pcm.default
pcm.sysdefault cards.pcm.default
pcm.front cards.pcm.front
pcm.rear cards.pcm.rear
pcm.center_lfe cards.pcm.center_lfe
pcm.side cards.pcm.side
pcm.surround21 cards.pcm.surround21
pcm.surround40 cards.pcm.surround40
pcm.surround41 cards.pcm.surround41
pcm.surround50 cards.pcm.surround50
pcm.surround51 cards.pcm.surround51
pcm.surround71 cards.pcm.surround71
pcm.iec958 cards.pcm.iec958
pcm.spdif iec958
pcm.hdmi cards.pcm.hdmi
pcm.dmix cards.pcm.dmix
pcm.dsnoop cards.pcm.dsnoop
pcm.modem cards.pcm.modem
pcm.phoneline cards.pcm.phoneline
pcm.hw {
@args [ CARD DEV SUBDEV ]
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_PCM_CARD
ALSA_CARD
default {
@func refer
name defaults.pcm.card
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_PCM_DEVICE
default {
@func refer
name defaults.pcm.device
@args.SUBDEV {
type integer
default {
@func refer
name defaults.pcm.subdevice
type hw
card $CARD
device $DEV
subdevice $SUBDEV
hint {
show {
@func refer
name defaults.namehint.extended
description "Direct hardware device without any conversions"
pcm.plughw {
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_PCM_CARD
ALSA_CARD
default {
@func refer
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_PCM_DEVICE
default {
@func refer
@args.SUBDEV {
type integer
default {
@func refer
type plug
slave.pcm {
type hw
card $CARD
device $DEV
subdevice $SUBDEV
hint {
show {
@func refer
description "Hardware device with all software conversions"
pcm.plug {
@args [ SLAVE ]
@args.SLAVE {
type string
type plug
slave.pcm $SLAVE
pcm.shm {
@args [ SOCKET PCM ]
@args.SOCKET {
type string
@args.PCM {
type string
type shm
server $SOCKET
pcm $PCM
pcm.tee {
@args [ SLAVE FILE FORMAT ]
@args.SLAVE {
type string
@args.FILE {
type string
@args.FORMAT {
type string
default {
@func refer
name defaults.pcm.file_format
type file
slave.pcm $SLAVE
file $FILE
format $FORMAT
truncate {
@func refer
name defaults.pcm.file_truncate
pcm.file {
@args [ FILE FORMAT ]
@args.FILE {
type string
@args.FORMAT {
type string
default {
@func refer
type file
slave.pcm null
file $FILE
format $FORMAT
truncate {
@func refer
pcm.null {
type null
hint {
show {
@func refer
name defaults.namehint.basic
description "Discard all samples (playback) or generate zero samples (capture)"
# Control interface
ctl.sysdefault {
type hw
card {
@func getenv
vars [
ALSA_CTL_CARD
ALSA_CARD
default {
@func refer
name defaults.ctl.card
ctl.default ctl.sysdefault
ctl.hw {
@args [ CARD ]
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_CTL_CARD
ALSA_CARD
default {
@func refer
type hw
card $CARD
ctl.shm {
@args [ SOCKET CTL ]
@args.SOCKET {
type string
@args.CTL {
type string
type shm
server $SOCKET
ctl $CTL
# RawMidi interface
rawmidi.default {
type hw
card {
@func getenv
vars [
ALSA_RAWMIDI_CARD
ALSA_CARD
default {
@func refer
name defaults.rawmidi.card
device {
@func igetenv
vars [
ALSA_RAWMIDI_DEVICE
default {
@func refer
name defaults.rawmidi.device
rawmidi.hw {
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_RAWMIDI_CARD
ALSA_CARD
default {
@func refer
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_RAWMIDI_DEVICE
default {
@func refer
@args.SUBDEV {
type integer
default -1
type hw
card $CARD
device $DEV
subdevice $SUBDEV
hint {
description "Direct rawmidi driver device"
device $DEV
rawmidi.virtual {
@args [ MERGE ]
@args.MERGE {
type string
default 1
type virtual
merge $MERGE
# Sequencer interface
seq.default {
type hw
seq.hw {
type hw
# HwDep interface
hwdep.default {
type hw
card {
@func getenv
vars [
ALSA_HWDEP_CARD
ALSA_CARD
default {
@func refer
name defaults.hwdep.card
device {
@func igetenv
vars [
ALSA_HWDEP_DEVICE
default {
@func refer
name defaults.hwdep.device
hwdep.hw {
@args [ CARD DEV ]
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_HWDEP_CARD
ALSA_CARD
default {
@func refer
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_HWDEP_DEVICE
default {
@func refer
type hw
card $CARD
device $DEV
# Timer interface
timer_query.default {
type hw
timer_query.hw {
type hw
timer.default {
type hw
class {
@func refer
name defaults.timer.class
sclass {
@func refer
name defaults.timer.sclass
card {
@func refer
name defaults.timer.card
device {
@func refer
name defaults.timer.device
subdevice {
@func refer
name defaults.timer.subdevice
hint.description "Default direct hardware timer device"
timer.hw {
@args [ CLASS SCLASS CARD DEV SUBDEV ]
@args.CLASS {
type integer
default {
@func refer
@args.SCLASS {
type integer
default {
@func refer
@args.CARD {
type string
default {
@func refer
@args.DEV {
type integer
default {
@func refer
@args.SUBDEV {
type integer
default {
@func refer
type hw
class $CLASS
sclass $SCLASS
card $CARD
device $DEV
subdevice $SUBDEV
