omarinho
I2c Table is full, but i don't have any i2c device conected.
Wed Dec 14, 2016 1:42 am
What is going on?
The i2c table is full of addresses but I don't have any device connected.
Can anyone help me?
I'm trying to use a BPM085 device.
Raspberry pi 2
cat /etc/debian_version 8.0
pi@OM_Raspi ~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
plugwash
Re: I2c Table is full, but i don't have any i2c device conec
Wed Dec 14, 2016 4:40 am
do you have appropriate pullups in place?
6by9
Wed Dec 14, 2016 7:05 am
SDA is shorted to ground, so it is seeing an ack to everything.
omarinho
Wed Dec 14, 2016 1:29 pm
Thanks guys for replying.
I'm still with the same trouble.
My setup of sensors:
3 DS18B20 (one wire) on gpio 24 with pullup resistor;
1 DHT22 on gpio 22 with pullup resistor;
Everything on 3.3v.
The BPM085 isn't pluggued.
SDA is disconnected. Not shorted to ground.
The CONFIG.TXT:
pi@OM_Raspi ~ $ sudo cat /boot/config.txt
# For more options and information see
# http://www.raspberrypi.org/documentatio ... fig-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=900
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c1=on
dtparam=i2c_arm=on
dtparam=i2c_arm_baudrate=100000
dtparam=spi=on
dtoverlay=w1-gpio,gpiopin=24
dtparam=i2s=on
#enable_uart=1
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (added by raspberrypi-sys-mods)
dtparam=audio=on
core_freq=500
sdram_freq=500
over_voltage=2
The file '/etc/modules' looks like this:
pi@OM_Raspi ~ $ cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
i2c-bcm2708
i2c-dev
Still showing the table full
I don't have any i2c device connected yet.
Last login: Wed Dec 14 11:02:41 2016
Any advice?
PeterO
Wed Dec 14, 2016 1:35 pm
Put a pull-up on SDA.
PeterO
Wed Dec 14, 2016 1:37 pm
It looks like you've got an I²C device on the bus that's permanently pulling SDA to GND. Check your wiring, have you got a device with SCL & SDA reversed.
Have you put your 1-wire device on the wrong pin (#5 rather than #7)?
http://pinout.xyz
6by9
Wed Dec 14, 2016 3:06 pm
/Etc/modules should NOT include i2c_bcm2708. Device tree should load that for you.
omarinho
Wed Dec 14, 2016 5:26 pm
PeterO wrote:Put a pull-up on SDA.
PeterO
Its already done.
joan
Wed Dec 14, 2016 5:31 pm
You have wired something incorrectly. Without a photo we can only guess at what.
omarinho
Wed Dec 14, 2016 6:00 pm
DougieLawson wrote:It looks like you've got an I²C device on the bus that's permanently pulling SDA to GND. Check your wiring, have you got a device with SCL & SDA reversed.
http://pinout.xyz
Thanks for your suport.
The SDA and SCL isn't reverse and using a pullup resistor.
the 1-wire was on gpio 24 (pin 18) and I changed to gpio 26 (pin 17), using a pullup resistor too.
I run some test:
1) I disconnect all devices and the i2c table runs ok, complete empty. I connect the BPM085 and the table show up just with te address 77 (0x77 = BPM085) . Fine.
2) I connect the DHT22 on gpio 22 (pin 15), reboot the Rpi and the DHT22 looks like fine. But the Table of i2cdetect show up full again.
3) I disconnect the DHT, reboot, then the table show up fine, just with address 77 (0x77 = BMP085) again.
4) I connect the 3 BS18B20 (1-wire) gpio 24 (pin 18) , reboot, and the table i2c is full again.
5) I disconnect the 3 BS18B20 and conect a single led on gpio 5 (pin 29) restart the Pi and the table show up full again, and again and again and again.
Conclusion for me:
This device runs just lonely. They don't like companion. I guess...It's so sad...
Another one advice, please???
omarinho
Wed Dec 14, 2016 6:31 pm
6by9 wrote:/Etc/modules should NOT include i2c_bcm2708. Device tree should load that for you.
Tanks for your suport.
I removed the i2c_bcm2708 from etc/modules.
i2c-dev
But still with the same problem.
Wed Dec 14, 2016 6:57 pm
Where's the photo of your wiring. Nobody can help without that.
omarinho
Wed Dec 14, 2016 11:27 pm
DougieLawson wrote:Where's the photo of your wiring. Nobody can help without that.
Photos on http://www.omarinho.com.br/bpm085.html
Everything was double-checked . All single connection, condutivity etc.
photo #1
This photo is only with BPM085 connected.
SDA >> gpio 02 (pin 03) yelow wire.
SCL >> SCL gpio 03 (pin 05) orange wire.
Pullup resistor 10k btw SDA and 3.3v.
GND brown wire
and 3.3v red wire.
photo #2
Screen with Home Assistant running showing no devices connected and terminal shows that bpm085 shows up : address 77 (0x77)
photo #3
Devices connected : BPM085 and
DHT22: 3.3v, gnd, gpio22 (pin15)
DS18b20 (one wire): 3.3v, gnd, gpio 26 (pin37)
Photo #4
Screen showing Home Assistant with DHT working fine and Terminal showing i2c table full of address.
photo #5
Screen showing Home Assistant with DHT and 2 DS18b20 working fine and Terminal showing i2c full of address.
Thu Dec 15, 2016 12:40 am
Can't see how that's wired to your RPi.
BMS Doug
Thu Dec 15, 2016 9:05 am
Its hard to make out any wiring details from those photos.
Doug.
joan
Thu Dec 15, 2016 9:22 am
As a matter of interest could you enter the following commands when you see the full I2C table.
sudo pigpiod
pigs mg 2 mg 3
omarinho
Thu Dec 15, 2016 11:36 am
joan wrote:As a matter of interest could you enter the following commands when you see the full I2C table.
sudo pigpiod
pigs mg 2 mg 3
Thanks for your patience.
Last login: Thu Dec 15 09:10:19 2016
pi@OM_Raspi ~ $ sudo pigpiod
pi@OM_Raspi ~ $ pigs mg 2 mg 3
1
4
joan
Thu Dec 15, 2016 11:41 am
Enter the following command and try the i2cdetect again.
pigs m 2 0 # zero
6by9
Thu Dec 15, 2016 12:01 pm
joan wrote:Enter the following command and try the i2cdetect again.
pigs m 2 0 # zero
0? That appears to set it to an input, when it needs to be ALT0 for I2C, which would be a value of 4.
joan
Thu Dec 15, 2016 12:07 pm
pigs m 2 0 # zero
The pigs m command uses r for input, w for output, 0-5 for ALT0 - ALT5.
omarinho
Thu Dec 15, 2016 12:22 pm
pigs m 2 0 # zero
pi@OM_Raspi ~ $ pigs m 2 0 # zero
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- 77
It's Work! Great! Thank you so very much, joan .
What happened? Teach me, I'm an eternal apprentice.
joan
Thu Dec 15, 2016 12:23 pm
@omarinho
I think our current guess would be your Home Assistant software is mucking up I2C by changing GPIO 2 (SDA) from mode ALT0 (I2C) to mode write.
You probably need to ask Home Assistant for a fix.
omarinho
Thu Dec 15, 2016 12:29 pm
joan wrote:@omarinho
Thank you again. Have a great nice day.
omarinho
Thu Dec 15, 2016 12:34 pm
All of you who tried to help me . Thanks so much. Joan solved the problem.
Have all of you a nice day.
Return to “Off topic discussion”
