g40
PXE Network Boot?
Tue Dec 13, 2016 1:53 pm
Greetings.
Does anyone has a working PXE boot set up? If so I wonder if it might be possible to get a wireshark trace of the proceedings?
My PI3 using the next firmware branch is not even getting to the TFTP stage. It issues 1 solitary DHCPDISCOVER and then goes quiet.
Many thanks for any possible assistance.
Jerry.
Re: PXE Network Boot?
Tue Dec 13, 2016 9:12 pm
The absolute crux of the problem is getting dnsmasq running with the right PXE option string.
port=0
dhcp-range=10.42.0.255,proxy
log-dhcp
enable-tftp
tftp-root=/tftpboot
pxe-service=0,"Raspberry Pi Boot"
If you follow the tutorial at: https://www.raspberrypi.org/documentati ... utorial.md it should "just work" unless something else on your network is serving up the DHCPOFFER packets.
g40
Wed Dec 14, 2016 12:26 pm
Yes, thanks, that link visited a good number of times. Sadly, and unlike other boards on the network, the Pi is no-go. I'll post if I get any further with this one.
Wed Dec 14, 2016 1:27 pm
Have you run the one-time boot to enable USB/PXE?
Have you tested that by booting from a USB?
The way I got it working was to build a USB stick with a bootable system on it. Then move that USB stick to my RPi2B so I could get the TFTP and BOOTP stuff running using the same bootable image (with a different command line and different /etc/fstab).
viewtopic.php?p=1034463#p1034463
