ApothLab
Rotate Pi LCD
Tue Dec 13, 2016 12:58 am
Hello all,
Recently I suffered a fatal error on my Kali OS for my Raspberry Pi. I reformatted and fixed the issue, however, my configuration settings were also wiped in the formatting.
I know the trick is to go into /boot/config.txt and type "lcd_rotate=2" but even after I do that and reboot nothing changes.
I think the problem is that it's not even looking at the config.txt, is there a way to mount it or prioritize it during the boot sequence?
Thank you!
Re: Rotate Pi LCD
Tue Dec 13, 2016 9:10 am
ApothLab wrote:Hello all,
Thank you!
Kali Linux has its own support forum: https://forums.kali.org
