Mettauk
Script to read A1120EUA-T Hall sensor error
Sat Dec 03, 2016 5:06 pm
Just trying to set up a hall sensor with this python script from http://www.raspberrypi-spy.co.uk/2015/0 ... ode]import RPi.GPIO as GPIO
import time
import datetime
def sensorCallback1(channel):
# Called if sensor output goes LOW
timestamp = time.time()
stamp = datetime.datetime.fromtimestamp(timestamp).strftime('%H:%M:%S')
print "Sensor LOW " + stamp
def sensorCallback2(channel):
# Called if sensor output goes HIGH
print "Sensor HIGH " + stamp
def main():
# Wrap main content in a try block so we can
# catch the user pressing CTRL-C and run the
# GPIO cleanup function. This will also prevent
# the user seeing lots of unnecessary error
# messages.
try:
# Loop until users quits with CTRL-C
while True :
time.sleep(0.1)
except KeyboardInterrupt:
# Reset GPIO settings
GPIO.cleanup()
# Tell GPIO library to use GPIO references
GPIO.setmode(GPIO.BCM)
print "Setup GPIO pin as input"
# Set Switch GPIO as input
GPIO.setup(19 , GPIO.IN)
GPIO.add_event_detect(19, GPIO.FALLING, callback=sensorCallback1)
GPIO.add_event_detect(19, GPIO.RISING, callback=sensorCallback2)
if __name__=="__main__":
main()
[/code]but keep getting this error
:~ $ sudo python hall2.py
  File "hall2.py", line 61, in <module>
RuntimeError: Conflicting edge detection already enabled for this GPIO channel
Any help would be much appreciated. Pi is updated with latest Jessie as at date of posting.
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
joan
Re: Script to read A1120EUA-T Hall sensor error
Sat Dec 03, 2016 5:17 pm
The RPi.GPIO module only allows one current add_event_detect() per GPIO. You could use one call to EITHER_EDGE instead which should work fine as long as edges aren't too frequent.
Mettauk
Sat Dec 03, 2016 7:30 pm
Thank you for your speedy reply. Unfortunately I don't understand how to edit the python script, can you give an example or explain a bit more?
Return to “Python”
