It works fine.
I do try to start a async routine that don't start. I don't know why?
I am able to run a time controlled routine by:
@classmethod
def write_to_clients(cls):
# print ("Writing to clients: ", cls.clients)
for client in cls.clients:
client.write_message("Ben je er?")
# print ("client : ", client)
tornado.ioloop.IOLoop.instance().add_timeout(datetime.timedelta(seconds=300), WebSocketHandler.write_to_clients) # herstart deze procedure na elke 5 minuten
if __name__ == "__main__":
con = mdb.connect('127.0.0.1', 'pi', 'raspberry', 'tempdb');
tornado.options.parse_command_line()
app = tornado.web.Application(
handlers=[
(r"/", WebSocketHandler)
httpServer = tornado.httpserver.HTTPServer(app)
httpServer.listen(options.port)
print ("Listening on port:", options.port)
tornado.ioloop.IOLoop.instance().add_timeout(datetime.timedelta(seconds=15), WebSocketHandler.write_to_clients) # start sturen van een controle bericht naar de nodemcu's na 15 seonde. routine: write_to_clients
tornado.ioloop.IOLoop.instance().start()
That works fine.
Now I do like to start an async gen.coroutine by:
@classmethod
@gen.coroutine
def minute_loop():
while True:
print( "Gen")
yield WebSocketHandler.write_to_clients()
yield gen.sleep(60)
handlers=[
tornado.ioloop.IOLoop.current().spawn_callback(WebSocketHandler.minute_loop)
sudo python3 webserver.py
Listening on port: 222
Gen
[E 161201 20:37:44 ioloop:585] Exception in callback functools.partial(<function wrap.<locals>.null_wrapper at 0x76157e40>, <tornado.concurrent.Future object at 0x761539d0>)
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/ioloop.py", line 565, in _run_callback
ret = callback()
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/stack_context.py", line 275, in null_wrapper
return fn(*args, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/ioloop.py", line 571, in <lambda>
self.add_future(ret, lambda f: f.result())
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/concurrent.py", line 109, in result
raise_exc_info(self._exc_info)
File "<string>", line 3, in raise_exc_info
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/gen.py", line 631, in run
yielded = self.gen.throw(*sys.exc_info())
File "webserver.py", line 101, in minute_loop
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/gen.py", line 628, in run
value = future.result()
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/concurrent.py", line 111, in result
raise self._exception
tornado.gen.BadYieldError: yielded unknown object None
new connection from : 192.168.2.133
^CTraceback (most recent call last):
File "webserver.py", line 118, in <module>
File "/usr/local/lib/python3.4/dist-packages/tornado-4.0.2-py3.4-linux-armv7l.egg/tornado/ioloop.py", line 812, in start
event_pairs = self._impl.poll(poll_timeout)
KeyboardInterruptWhat is wrong ?? And what is the change for the code I need to make
