PI_newbee
Piface 2 relay board -- suggestion
Mon Nov 28, 2016 10:33 pm
Hi to all.
I need to trigger 12V DC electro door lock.
1.) Would this be possible to make with piface
2.) If not, what would be best substitution ?.
I have sainsmart 2 relay board ( 12V omron relays ) but for some unknown reason i can not trigger it.
As power supply for this module am using standard 12V DC adapter...
Best regards !
W. H. Heydt
Re: Piface 2 relay board -- suggestion
Tue Nov 29, 2016 5:08 am
You need to contact a company that makes and sells the PiFace board. It's not put out by the RPF/RPT.
PI_newbee
Tue Nov 29, 2016 8:19 am
Thank you for your suggestion, i will do that.
Tell me, did you work with sainsmart 2 relay boards (12V ) ?
Maybe i can use this instead of piface...
PIN
W. H. Heydt
Tue Nov 29, 2016 2:32 pm
PI_newbee wrote:Thank you for your suggestion, i will do that.
PIN
Sorry...I haven't used either board. My projects are mostly software rather than hardware.
