xiaozai
Combining two ping command using python
Fri Nov 25, 2016 4:21 pm
I have two working command that check a device up/down and copy packet loss value.
For checking a device up and down i used
result = os.system ("ping -c 5 " +hostname)
For copy a packet loss value, i used
packetloss = os.popen ("ping -c 5 " +hostname+ "| grep -oP '\d+(?=% packet loss)'").read().rstrip()
packetloss = int(packetloss)
I know its not practical to use os.system. My question is how to combine both of the command? For now i need to ping two times just to get device up/down and another ping to check the packet loss value. How can i just ping once to get both result? Its time consuming if i keep ping the same device two times
B.Goode
Re: Combining two ping command using python
Fri Nov 25, 2016 4:58 pm
(I thought I had seen this query earlier today, but I can't find it in the forums now. Odd?Or impatient?)
Presumably if the target is not accessible you will not get a meaningful value for packet loss?
Or issue the ping once, store the information it returns, and then process that output in multiple ways?
davef21370
Fri Nov 25, 2016 5:39 pm
import subprocess
url = "www.google.com"
ping = subprocess.Popen(["ping", "-n", "1", url], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
print ping.stdout.readlines()
Parse the output and you should get what you need.
Dave.
Apple say... Monkey do !!
Fri Nov 25, 2016 8:31 pm
Return to “Python”
