klintkrossa
Core Voltage
Wed Nov 23, 2016 7:56 am
What is the safe core voltage?
upper and lower.
import os,re
stream = os.popen("sudo bash volt").read()
print (stream)
volt = re.findall("\d{1}\.\d{1,4}", stream)
volt = list(map(float, volt))
volt1 = volt.pop()
if volt1> 1.0:
    print('greater that')
else:
    print ('less than')
This script should create a shut down for battery operation. replacing print with os,..halt
of course that is what I get for typing late at night. forgot this code
#! /bin/bash
for id in core
do
    echo "$(vcgencmd measure_volts $id)"
done
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
davidcoton
Re: Core Voltage
Wed Nov 23, 2016 9:47 am
klintkrossa wrote:What is the safe core voltage?
upper and lower.
import os,re
print (stream)
volt1 = volt.pop()
if volt1> 1.0:
else:
    print ('less than')
You can't monitor battery state by looking at core voltage. The core voltage is regulated and won't go down until the battery resembles a pancake.
You have to monitor the 5V supply, there is no onboard A2D to give a value. You can monitor the low voltage (4.63V IIRC) warning, and shut down when that appears. Whether there is enough time left to shut down when the warning appears will depend on the converter circuit used with the battery. Otherwise you will need an add-on A2D, preferably monitoring the actual battery voltage rather than the 5V converter output.
Signature retired
klintkrossa
Re: Core Voltage
Wed Nov 23, 2016 3:02 pm
upper and lower.
import os,re
print (stream)
volt1 = volt.pop()
if volt1> 1.0:
else:
    print ('less than')
:cry: :cry: that is no good. how would I find the IIRC in script?
Re: Core Voltage
Wed Nov 23, 2016 3:36 pm
IIRC means "If I remember correctly" it's not something you can search for.
You will need to use external hardware to monitor your battery, you can't do it using anything on your RPi. The only indication of low voltage/current is the lightning bolt icon on screen and a GPIO signal, but by the time you reach that point with your flat battery your RPi will already be crippled and your SDCard will be at risk of corruption. You need to trigger a shutdown while you still have enough power budget to achieve an orderly poweroff.
On old Raspberries it was GPIO35. That's probably not true with a RPI3 and may not be true with a RPI2V2.
viewtopic.php?t=82373
Return to “Advanced users”
