I have problem with javaFX applications on RPI. I'm following the instructions included here: http://chriswhocodes.com/
I downloaded latest JDK 8_111 and openJFX from this url and unpacked jdk and then openJFX with command:
unzip openjfx-8-sdk-overlay-linux-armv6hf.zip -d /home/pi/jdk1.8.0_111Code: Select all
jdk1.8.0_111/bin/java -jar BasicFX.jarCode: Select all
Exception in Application start method
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:389)
at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:328)
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:767)
Caused by: java.lang.RuntimeException: Exception in Application start method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:917)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$1(LauncherImpl.java:182)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ExceptionInInitializerError
at javafx.scene.Node.reapplyCss(Node.java:8983)
at javafx.scene.Node.impl_reapplyCSS(Node.java:8946)
at javafx.scene.Node.invalidatedScenes(Node.java:854)
at javafx.scene.Node.setScenes(Node.java:919)
at javafx.scene.Parent.scenesChanged(Parent.java:659)
at javafx.scene.Node.invalidatedScenes(Node.java:853)
at javafx.scene.Scene$9.invalidated(Scene.java:1119)
at javafx.beans.property.ObjectPropertyBase.markInvalid(ObjectPropertyBase.java:111)
at javafx.beans.property.ObjectPropertyBase.set(ObjectPropertyBase.java:146)
at javafx.scene.Scene.setRoot(Scene.java:1072)
at javafx.scene.Scene.<init>(Scene.java:347)
at javafx.scene.Scene.<init>(Scene.java:223)
at basicfx.BasicFX.start(BasicFX.java:31)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$8(LauncherImpl.java:863)
at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$7(PlatformImpl.java:326)
at com.sun.javafx.application.PlatformImpl.lambda$null$5(PlatformImpl.java:295)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$6(PlatformImpl.java:294)
at com.sun.glass.ui.monocle.RunnableProcessor.runLoop(RunnableProcessor.java:92)
at com.sun.glass.ui.monocle.RunnableProcessor.run(RunnableProcessor.java:51)
... 1 more
Caused by: java.lang.NullPointerException
at com.sun.javafx.font.PrismFontLoader.loadFont(PrismFontLoader.java:196)
at javafx.scene.text.Font.<init>(Font.java:319)
at javafx.scene.text.Font.getDefault(Font.java:86)
at javafx.scene.CssStyleHelper.<clinit>(CssStyleHelper.java:1528)
... 22 more
Exception running application basicfx.BasicFX
Regards,
Kamil
