razatherogue
dagu rover 5 help
Mon Nov 21, 2016 9:10 pm
Can I cut wires on the Dagu Rover 5? I don't need the encoder wires (which I think are the thick ones, correct me if I'm wrong) so is it ok to cut them? Or should I leave them as is?
Also in the guide I am following the rover only has two motors but the one i have has 4? Please help
mikronauts
Re: dagu rover 5 help
Mon Nov 21, 2016 9:29 pm
NO. Bad idea, as you will likely need them in the future. Just ignore the encoder leads.
There are two and four motor Rover 5's, I have both types, and I've never heard of a three motor one.
Post a link to your bot.
razatherogue wrote:Can I cut wires on the Dagu Rover 5? I don't need the encoder wires (which I think are the thick ones, correct me if I'm wrong) so is it ok to cut them? Or should I leave them as is?
Also in the guide I am following the rover only has two motors but the one i have has 3? Please help
razatherogue
Mon Nov 21, 2016 9:42 pm
Whoops, I meant 4. Here is the link
https://www.sparkfun.com/products/10336
mikronauts
Mon Nov 21, 2016 9:57 pm
Yep, I have a couple of those.
Don't cut the wires, you will later regret it.
razatherogue wrote:Whoops, I meant 4. Here is the link
razatherogue
Mon Nov 21, 2016 10:12 pm
So which motors do I connect? My controller board only has 2 motor controllers, not 4.
mikronauts
Tue Nov 22, 2016 1:42 am
Wire the two motors on each side in parallel.
Make sure the motors on each side go in the same direction (ie take the tracks of for testing)
Make sure your motor driver board can drive as much current as the two motors on each side need.
razatherogue wrote:So which motors do I connect? My controller board only has 2 motor controllers, not 4.
